boot cover coming loose
Old May 14, 2001 | 09:43 AM
mister_two's Avatar
Like a lot of people, I have the problem of the backend of the boot cover working itself loose and flopping around during high speed driving. From another thread, I have learned the trick of pushing the boot down and pulling/pushing the boot towards the back of the car. That has helped but it still manages to come loose occasionally. It appears that the two tabs on the backend of the boot is just too short to catch or clip underneath the trunk rubber. Has anyone tried, somehow, extending the two tabs so it has a larger area to slide underneath the trunk rubber. That may stop the boot from coming loose at the rear. Any help would be much appreciated. Thanks.
Old May 14, 2001 | 09:56 AM
wanabe's Avatar
would be helpful for us to know what year car you have and if you have the 2000, whether you have the improved boot or the original one. i have never had this problem with my boot, and it is on all of the time.
Old May 14, 2001 | 10:07 AM
mister_two's Avatar
It's a MY2000. bought it in Nov 2000. #7599. What's the difference with the improved boot ?
Old May 14, 2001 | 10:34 AM
ankuse's Avatar
I have the same problem with my 2001 s2k, and i was also thinkin about extending the tabs or something, cuz its such a pain to see it flapping all the time
ankur
Old May 14, 2001 | 10:54 AM
andrewewing's Avatar
I posted this previously but apparently it wasn't seen. About 2 weeks ago I extended my tabs and it pretty well fixed the problem. I used sheet aluminum from an old Radio Shack chassis, about .050 thick--needs to be thin but stiff. Cut 2 pieces approx width of the tabs and long enough-front to back measurement-to approx double the amount that tucks under back of car. Used 2 1/8 pop rivets to attach to existing tabs.
Old May 14, 2001 | 11:01 AM
S2k Dude's Avatar
Mister, are you putting a "Miata tube" between the plastic layers of the window?
I noticed that if the tube is too large the problem is more pronounced.
I moved to a smaller diamter window protector tube and that helped.
Old May 14, 2001 | 11:07 AM
txst's Avatar
I too have this problem. What I noticed is that the top doesn't stay down all of the way when going over rough roads. If the boot pops up, I can pull over and reach under the cover to press the top down, and the cover will stay put for a while again. In my case, the roof latch on the drivers side seems to push up on the cover. I was thinking of trying to come up with something that will keep the latch folded down to see if that helps.
Old May 14, 2001 | 11:21 AM
mister_two's Avatar
thanks Andrew, I went back to search your thread. I may just follow your tip.
No, I don't use a miata tube, just the Muz mat.
Csand
Sep 7, 2015 01:48 PM
slalom44
Jun 3, 2003 06:50 AM
jallen1217
Jul 6, 2001 08:23 PM
