retracting piston on front brakes
Old Aug 2, 2001 | 07:53 PM
cthree's Avatar
Administrator
Default retracting piston on front brakes
How do I do this? I turn it clockwise but how? HELP!!!
Old Aug 2, 2001 | 07:55 PM
gabedude's Avatar
Push on it. Hard.
Old Aug 2, 2001 | 07:56 PM
gabedude's Avatar
A C Clamp and old brake pad usually helps.
Old Aug 2, 2001 | 08:26 PM
Tanqueray's Avatar
Just push really hard with your fingers on the rim of the piston. You don't have to move it very far...make sure that you haven't offset the caliper relative to the rotor on the caliper pin.
Old Aug 2, 2001 | 09:11 PM
gregstevens's Avatar
Banned
You could do it with you r fingers, but just get a c-clamp and use an old brake pad to push it back in.
Much MUCH easier...!
Oh, and only the rear pistons SCREW in...the fronts need just flat pressure...
Old Aug 2, 2001 | 09:50 PM
cthree's Avatar
Administrator
thanks everybody. I figured out the c clamp thing myself. I was just panicing All done, good as new.
Old Aug 3, 2001 | 04:04 AM
Tim S2K's Avatar
Do the rear pistons screw 'IN' clockwise?
Old Aug 3, 2001 | 05:02 AM
CoralDoc's Avatar
Yes
Old Aug 3, 2001 | 07:17 AM
amartin's Avatar
Release the top of the master-cylinder (open it), then you can use a flat headed screwdriver to compress it...very easy. On the rears, do the same thing, but you turn them clickwise to make them go in, instead of compressing them with a screwdriver...
-- Aaron
Old Aug 3, 2001 | 08:00 AM
amartin's Avatar
BTW, there is a front AND rear master cylinder top you'll need to open.
-- Aaron
erikvanden
Sep 9, 2011 12:44 PM
cannonball
Oct 9, 2010 08:48 AM
Terry Kwok
Dec 7, 2009 01:38 PM
drewchie
Sep 1, 2004 10:07 PM
S2K_LA
Mar 9, 2002 04:06 AM
