Breaking the tires loose
Old Apr 13, 2004 | 07:19 PM
GotRPMs's Avatar
Default Breaking the tires loose
I recently had a flat on the rear and replaced the rear s02's with s03's of a comprable size. Also this weekend i installed an AEM cai, the rest of the car is stock. So my question is recently i have been able to spin the tires much easier than before, so are the s03's not as sticky of a tire, or did the little horsepower i gained make that much of a differance, or is it a combination of the two. Thanks
PS Did you guys know our OEM wheels are made by enkei, just a bit of info.
Old Apr 13, 2004 | 07:29 PM
GotRPMs's Avatar
please someone must have a little advice
Old Apr 13, 2004 | 07:34 PM
wanabe's Avatar
s02s are about the most sticky tire you can run... so3s are wider but will break, which is what you experienced most likely- not the aem.
Old Apr 13, 2004 | 07:41 PM
23psi4age's Avatar
yeah s03's will let loose a little earlier than the s02's.
Old Apr 13, 2004 | 07:42 PM
GotRPMs's Avatar
are they just not as good of a tire, i mean do the s03's have benifits over the s02's
Old Apr 13, 2004 | 07:47 PM
23psi4age's Avatar
i feel they are better in the wet. but only slightly. i also think they last longer.
Old Apr 13, 2004 | 07:51 PM
wanabe's Avatar
[QUOTE]Originally posted by 23psi4age
Old Apr 13, 2004 | 07:52 PM
RazorV3's Avatar
i can only get the s02's to break traction on 1st->2nd shifts and engaging vtec on a turn. s02's are very grippy.
Old Apr 13, 2004 | 07:58 PM
GotRPMs's Avatar
Thank you because i thought that my cai was magicaly boosting my hp, becasue now on certain conditions i can floor it in first and git a little wheel spin when vtec engages, thanks for all of your help.
Old Apr 14, 2004 | 04:49 AM
Russ's Avatar
Indeed, the wheels are made by Enkei, who make quite a few OEM wheels for various
manufacturers. Ironic isn't it? Considering the S2000 wheel snobs who look down upon Enkei as
an inferior wheel brand.
I always get a kick out of that one, thanks for reminding me.
