Broken plastic under the pedals? Car won't start
Old Sep 3, 2022 | 11:05 AM
fxs2000's Avatar
Default Broken plastic under the pedals? Car won't start
When I press the start button nothing. Everything was fine a day ago. I found this plastic pieces under the pedals. Does anyone know where this come from. I check everything, fuses, battery, everything is fine. The dash lights up as normal. It is just nothing when I press the Start button.
Old Sep 3, 2022 | 11:07 AM
spider2k's Avatar
Active Streak: 30 Days
Clutch switch?
Old Sep 3, 2022 | 02:53 PM
Car Analogy's Avatar
Clutch interlock switch. You can temp bypass switch with a paperclip to be able to start it.
Replace plastic pad when you can.
Old Sep 4, 2022 | 07:16 AM
fxs2000's Avatar
I found the clutch plastic piece on the mat this morning, it looks white. I'm still not sure where that black spacer in the in the picture above comes from. Thanks guys!
Old Sep 5, 2022 | 08:33 AM
cosmomiller's Avatar
Top Answer: 1
I believe the part is identical to Honda manual cars but has a different part number for the S2000. If it shows unavailable, ask a dealer to see if they have the one that matches for another Honda Car.
mcraw152
Sep 24, 2020 12:44 PM
topDown99
May 16, 2019 07:23 PM
matt0488
Mar 21, 2015 03:02 PM
only9k
Mar 18, 2015 08:52 PM
prorcracer87
16
Sep 15, 2007 02:15 PM
