Bucking S 2000
Old Mar 26, 2004 | 02:46 PM
  #21
xviper's Avatar
That is but one option and one possibility. You need to first make sure all the existing parts are functioning up to spec. A bad MAP sensor will only plague any future tuning regardless how fancy an add on you try next.
Old Mar 26, 2004 | 02:56 PM
  #22
E36Ap1's Avatar
I thought this was me as a driver. I did notice that I did it a couple of times once next to RSX and the driver was looking at me funny. I thought there was something wrong with the clutch like it got overheated or something.
Old Mar 26, 2004 | 10:22 PM
  #23
djweaver's Avatar
Had the same problem. On the occassions it happened, it always occured when a high speed commute suddenly became a crawl < 5mph.
I found a solution that worked for me.
I read in a thread here last year that the S2000 is often delivered with the throttle cable exceedingly loose. It was referred to as the "granny factor" Honda used to make sure the car's responsiveness was restricted so uninitiated drivers didn't "jack rabbit" into the car in front of them when accelerating from a dead stop.
Sure enough, I took it in and the dealer found it had about 3/4" of excess play ... adjusted it and have never had the problem since. It also made the car a bit more response on acceleration.
Old Mar 26, 2004 | 11:02 PM
  #24
alexf20c's Avatar
Wait, there's a THIRD pedal? No wonder my shifting always grinds and jerks. Could this also be the reason for my frequent stalls when leaving traffic lights?
Old Mar 29, 2004 | 05:48 PM
  #25
mbilderback's Avatar
Er, here's a consideration, why not just take off in 2nd, a bit more clutch wear, but nothing that's out of the ordinary. I encourages the higher use of clutch (Necessary with this car in slow traffic) and you'll give it a bit more RPMs to work with when starting off. Try just staying in 2nd, and think about it, with such a close ratio in the tranny, it's easy to start in 2nd.
Old Mar 29, 2004 | 06:52 PM
  #26
xviper's Avatar
[QUOTE]Originally posted by mbilderback
Old Mar 29, 2004 | 06:56 PM
  #27
You're probably right, but I was only saying do that in very limited circumstances. I'd think that bucking your engine would be more dangerous than burning a bit more off the clutch as often? And I think that the clutch play in 1st would be nearly as much as in 2nd?
Old Mar 30, 2004 | 08:52 AM
  #28
R11's Avatar
R11
It seems to me that there are two different things that are being reported in these "bucking" threads. One sounds like a momentary hiccup from the metering system after extended running and then coming to a slow crawl. The other is just normal lugging while creeping along in traffic. Since lugging happens in large part because you are going too slow for the gear you are in, putting it in a higher gear would only serve to make it worse and will definitely cause extra stress/wear on the clutch.
ron
Old Mar 30, 2004 | 09:04 AM
  #29
xviper's Avatar
I'm going to say no on this one too. You need to achieve a certain road speed when moving off before the clutch can be completely engaged. If you move off in 2nd, your road speed will have to be higher to get beyond that threshold rpm so as to not lug the engine. Only once you've reached that road speed/rpm can you fully release the clutch. Before this "threshold", the clutch must slip in order for the engine to run at a more "comfortable" higher rpm. It is only logical that you would have to slip the clutch much longer if starting out in 2nd.
An example (although not an S2000 but still relavent):
My son drives a manual pickup truck (RWD). One year ago, he had a new clutch put in. Someone told him to NEVER start out in 1st but to start out in 2nd all the time. He did this for the last year. He just had another new clutch put in last week. And keep in mind that 1/2 his driving was in slippery winter conditions.
Old Mar 30, 2004 | 11:13 AM
  #30
BlitzSRM's Avatar
This just happened to me Saturday in Waikiki Traffic.
What sucked is everybody was looking, top down
My wife was riding with me and said "you don't know how to drive".
I'm going to send her this link.
