Camber Question
Old Apr 27, 2010 | 02:18 PM
rikhemi's Avatar
Default Camber Question
Hey guys,
I lowered by car like 4 months ago on stock struts with Tein springs. I have the Tein springs which lower the car 1.25 inches all around. I purchased new tires for the rear since I noticed it was wearing out on the inside. Once i purchased the new tires, I went to firestone to get the car alligned. Once finished, they told me the camber was maxed out and still not to stock specs. I belive it was aorund 2.4 on one side and 2.2 on the other side. I thought if you lowered the car with a small drop that the camber could be adjusted. Is this right? Do I need a camber kit?
Thanks in advanced.
Old Apr 27, 2010 | 02:21 PM
s2k dre's Avatar
With that drop u should be able to get the camber to -1.5 atleast. U need an s2000 alignment guy for sure.
Old Apr 27, 2010 | 02:28 PM
rikhemi's Avatar
This guy was a nice guy and even showed me where it was maxed out. He let me see where on the rear the bolt was pushed all the way to the right where you would adjust it. He said its not too bad on how off it is and that normally mercedes are like this since it grips better.
Old Apr 27, 2010 | 03:03 PM
estooki's Avatar
i have tein springs with koni yellows on low perch, my camber is maxed out with running -2 but my toe is in spec. i been driving for a while and haven't really noticed any uneven wearing of the tires
Old Apr 27, 2010 | 03:10 PM
daktruckie99's Avatar
All the adjustments work together, the camber might be maxed but if you play with the others it'll change the camber.
I have -2 on that suspension, you need a different shop if he gave up that easy.
Old Apr 27, 2010 | 03:49 PM
Disgustipated's Avatar
Where do you live? Definitely go to a performance shop to get it done. I go to Evasive Motorsports in SoCal, you should go somewhere similar with people who KNOW S2000 suspension/alignment.
Old Apr 27, 2010 | 04:10 PM
nartnailuj's Avatar
that just happened to me too when i tried to get my car aligned. they said it was so out of spec. what should i tell them too? does anyone know a good shop in sacramento?? that has s2000 knowledge.
Old Apr 27, 2010 | 09:15 PM
B serious's Avatar
If you fix the toe, the tires aren't going to be wearing out dramatically on the inside anyway. I run like 3 degrees of camber on both my cars. No inside wear issues. I just run toe within spec.
Old Apr 27, 2010 | 09:43 PM
NFRs2000NYC's Avatar
The maximum stock s2000 negative camber is -3.5, or in alignment terms, -3:30. My car is set to maximum.
Old Apr 28, 2010 | 08:36 PM
B serious's Avatar
Why?
orbels2k
Apr 15, 2011 11:51 AM
seoul2k
Oct 5, 2009 10:16 PM
ap2s2klover
Mar 25, 2009 06:35 PM
minh
May 3, 2007 02:43 PM
jdnissanz
Apr 21, 2005 10:19 PM
