can fit brake pads on rotor?? help...
Old May 1, 2004 | 05:11 PM
Black01S2k's Avatar
Default can fit brake pads on rotor?? help...
Hey my back brakes just went and i was going to change them this afternoon, ive done several brake installs in my life and the last was a while ago but i dont know if i am forgetting a step or not but i put the back side pad in and there is not enough room to fit the front side pad. I cannot get the caliper to contract, i dont know if i am forgetting how or if my caliper is shot, the brakes did get pretty bad before i changed them just because my rotors took forever to come in. Is my caliper shot or how do i get it too contract so the two pads will fit around the rotor??? help would be greatly aprecialted !!!
Old May 1, 2004 | 05:17 PM
hygiene boy's Avatar
More than likely you need to push in the piston on the caliper. Some people use a C - clamp or a very large pair of plyers. If that is not it confirm that you got the right pads. I did not read close enough . . . I stand corrected . . . as I thought he was changing fronts as they are the first to go. Yes the backs do need to be screwed in.
Old May 1, 2004 | 05:18 PM
Punisher's Avatar
gotta compress the piston
Old May 1, 2004 | 05:49 PM
t.c.'s Avatar
I've never change rear pads on the ( s ) but on a car equiped with drum brakes ( I know the s doesn't have drums !! )
You have skrew on the adjustment properly.
Old May 1, 2004 | 06:33 PM
dhayner's Avatar
Pushing the piston into the caliper won't do it. On rear brakes, you have to screw the piston in. This is because of the self-adjuster for the parking brakes. Be sure the peg on the pad lines up with the groove in the piston.
Old May 1, 2004 | 07:31 PM
vjarnot's Avatar
Yeah, just use a 3/8ths socket wrench (without a socket) to screw the piston in - perfect tool for the job...
Old May 1, 2004 | 07:40 PM
Nobody's Avatar
Hmmm...never tried just a 3/8" socket. Most auto parts stores sell a tool specifically made for screwing pistons back for about $6.
Old May 1, 2004 | 07:42 PM
Ludedude's Avatar
Administrator
STOP! DO NOT TRY TO PRESS THE REAR PISTON IN WITH A C-CLAMP!
OK, now that I have your attention. The rear pistons on the S2000 calipers get retracted by screwing them back into the caliper. You can use a standard 6" 3/8" extension in a ratchet to do the job. No socket, just fit the square end of the extension into the center of the X and turn clockwise until it's properly retracted.
There is a special tool available that fits into the X but it's really not necessary.
For more on this procedure, please see this excellent thread. http://forums.s2ki.com/forums/showthread.p...threadid=123081
Gatsbee13
Feb 15, 2016 07:05 PM
Mr-T
Mar 4, 2015 06:03 AM
SDueces
Mar 2, 2014 09:24 PM
PierreC
Apr 11, 2012 09:20 AM
Scott2000
Nov 20, 2006 12:57 PM
