Can you help identify this buzz sound from AP1
Old Feb 20, 2026 | 06:32 PM
PDXManual's Avatar
Default Can you help identify this buzz sound from AP1
I am noticing this buzz sound when I am lightly cruising in 2,3 or 4th. This buzzing resonance sound starts when I let go the clutch but goes away when I speed up. It sometimes gets pretty noticeably loud. It’s not engine or exhaust sound, it’s coming under the driver seat.
Thank you in advance for your help.
File Type: mov
Old Feb 21, 2026 | 01:59 AM
SilentWrath*'s Avatar
I didn't look at your video, but clutch buzz was a common phrase used to describe a noise which eminates from the trans tunnel into the cabin on AP1s. AP2s did not have this noise, if I remember correctly due to the added mass on the flywheel
Old Feb 21, 2026 | 09:36 AM
MaintenanceObsessed's Avatar
Am I going crazy or is this the third time this video was posted with a different question?
Anyway, I can barely make out the sound. Do you mean that winding sound? I can hear it three times. It doesn't sound like clutch chatter, and it doesn't sound like a throwout bearing which tends to make more of a whirring or squeaking sound. How does your clutch pedal feel? Is it soft, like you can press it in with one finger, or is it stiff like it requires you pushing it with your whole hand? It'd probably be a good idea to use a stethoscope and listen to the bell housing to see if it's coming from the clutch or trans. That'd be the best way to diagnose it.
Old Feb 21, 2026 | 02:46 PM
PDXManual's Avatar
The clutch feels ok. This buzz resonance sound comes on between 3-4k rpm when decelerating. Foot off the gas pedal. Can hear it pretty noticeable in 3rd gear but you hear it from 2-4 gear, even a hint on 5th. It goes away when you accelerate. It’s very noticeable in cruising speed.
Old Feb 21, 2026 | 03:09 PM
It's what everyone refers to as "clutch buzz" a quick Google search of "s2000 clutch buzz" will net you a multitude of results. I was wrong about the flywheel being the "cure" it happened with the oem clutch disc in early AP1s due to spring design originally which Honda fixed, but according to resident s2000 expert billman, it occurs with other non oem discs as well:
Originally Posted by Billman250
I have installed every disc you can imagine. They all buzz except oem. Oem is the only way to go for the disc.
https://www.s2ki.com/forums/s2000-un...z-cure-985766/
ChrisIsa
Mar 14, 2025 11:33 AM
henrryxd
Jun 13, 2013 11:37 AM
ATL_S2K
Dec 4, 2009 06:01 AM
killyougood
Jul 8, 2008 12:45 PM
mr_2000
Nov 13, 2006 02:22 PM
