Canyons, hard on the car?
Old Jul 17, 2007 | 01:14 PM
  #21
plokivos's Avatar
make sure you let the brake pads cool down before you park it. You might cook it if you stop right away after a hard run.
that and make sure to let the engine run for a bit, parked, after a hard run. You don't want the oils cooking, you want the oil to circuate and cool for a bit.
turbo timers work good for NA engines. It's the same principle as the turbo cars. (Because most modern turbo's are oil and water cooled, you don't really need to cool the turbo, but it'll help on the longevity of the engine/turbo, other components since heat is the worst enemy of the engine).
just my 2 cents.
Old Jul 17, 2007 | 02:54 PM
  #22
B.Money's Avatar
how long roughly of course would you guys say to let the brakes cool before setting the parking break. And how long to run the engine at a stop. Thanks again guys
Old Jul 17, 2007 | 04:46 PM
  #23
steadyc's Avatar
If you have a brake pedal pulsation..the rotors are warped. That can be caused by a number of factors. If you over tighten the wheel lugs... warped rotors can be a result. Of course it could also be your ABS kicking in. If they are warped you're better off getting new rotors, and torque the lugs to factory specs.
Old Jul 17, 2007 | 05:54 PM
  #24
plokivos's Avatar
10 minutes should be more than sufficient. or even 5 minutes better than just shutting it down.
Old Jul 17, 2007 | 06:00 PM
  #25
Ks320's Avatar
Originally Posted by B.Money,Jul 17 2007, 01:04 PM
lol my breaks already feel kinda like there is slight vibration in the petal. Is this something that I shouldnt be running on? its only under breaking with speed probably like 70+ lol. Should i get them shaved and throw my new pads on um?
if your car vibrates when u brake ... ur rotors might be warped ... should get that checked out man
Old Jul 17, 2007 | 08:46 PM
  #26
B.Money's Avatar
yea i know its not ABS kicking in.. i think they are lightly warped. is there anything bad about running your car with warped rotors besides it vibrating? lol. I mean I know i need to get it fixed but should it be ASAP?
If so, whats a good rotor to get with oem pads? oem rotors? or is there something better for the same price...give or take a little...
DJ Maestro
Jul 10, 2012 08:20 AM
rotaman
Jul 19, 2008 01:20 PM
Kwyjibo
Feb 24, 2006 01:42 PM
cutter60
Nov 2, 2003 02:06 PM
pccitg099
Oct 24, 2001 04:53 PM
