car does werid stuff at high speeds???????
Originally posted by TTSUPRA
Ok heres a second problem I have well when I hit bumps I would have a rattle (really loud) coming from the pass side seat area well ever since this has occurd the pass seat is extremely hard to adjust like u cant even do it while your sitting i have to get out of the car and put a decent amount of muscle into it. The seat was never like this untill the rattle started.
My only rattle from the passenger seat is from the seatbelt buckle on the door panel.
My passenger seat seems to move fine, but I do have a rattle coming somewhere from the passenger side. I can't tell if it's something in the door panel or something in the roof assembly.
whats good to lube it with thats not to messy??
The rattle in my car comes from the seat back vibrating against the plastic backing (happens whenever you hit a big bump). All you have to do is move the seat up so it has clearance between the seatback and the plastic backing.
Originally posted by RJ_S2K
It sounds like it's coming from inside the door.
https://www.s2ki.com/forums/showthread.php?...?threadid=39914
All,
If you experience random vehicle handling at different speeds, then check under you car. I had some fluid leaking near the left rear axle. I ruptured a fluid filled shock mount as per the service technician?
The car would pull in one direction under acceleration and another while decelerating.
Fixed and all is wonderful. I thought is was tire pressure, also.
-Skip
-Skip
