Car pulling to left under thottle
NO. Check your tire pressure in your rear tires and make sure they are the same. If that's not it, come on back, but I bet that's it. I wouldn't be surprised if your left rear has a hole...
that might be it....I just filled then sunday but i when I checked the left rear was low...which tires would you suggest i know the s0e's are choice but what other ones compare and have same width cause I heard something the so3's are wider than normal 225's
Actually, you have it backwards. The S02's are wider 225's than normal. Any other tire you get, you will want in 245's.
Check the Tire Rack forum FAQ's for tire widths and comparisons.
