Check Engine light again - Engine Coolant sensor
Old Nov 19, 2000 | 08:30 PM
VaporTrail's Avatar
For the third time, my check engine light has come on. All 3 times it has come on, it has been after extended down time, during which a temperature swing colder occurs. It immediately comes on about 5-15 seconds after starting, during the warm up cycle. The last time it came on, I had Honda scan the code. The code was engine coolant temperature sensor, specifically engine coolant temperature too low. The thermostat opens and closes normally, and coolant levels are optimum. I have not yet even touched the cooling system in any way on this car, so it's not due to modifications performed. The dealer recommends having the sensor replaced, I will probably do that, but I also wonder if it's not the ECU flipping out.
Has anyone else had similar problems, and if so, what was the resolution (if achieved)? Much thanks in advance.
Old Nov 19, 2000 | 08:42 PM
Schatten's Avatar
interesting, for a second there, I was thinking it would be a few mods that would trip off the light. hope you find out more info.
f20cpower3
Apr 15, 2010 01:14 PM
Tommi1980
Aug 21, 2009 11:49 AM
ivanvinigo
Jul 8, 2006 05:47 PM
Mirror
Sep 4, 2004 10:02 AM
