Cloth Soft Top
hi guys im new to the forum as ive just got my first s2k
there is a slight issue with the roof leakin through the seal that folds which is cenral to the side window and dont kno wether this is due to the seam or stitch (just above the window)letting water through maybe,the water only drips in from this fold but if you hit the breaks it seems to travel to the front two corners and starts to almost trickle in from there too!!
any help tips or advice on products i can use to resolve this problem will be much appriciated
summer isnt around forever ha ha
thanks mitch
there is a slight issue with the roof leakin through the seal that folds which is cenral to the side window and dont kno wether this is due to the seam or stitch (just above the window)letting water through maybe,the water only drips in from this fold but if you hit the breaks it seems to travel to the front two corners and starts to almost trickle in from there too!!any help tips or advice on products i can use to resolve this problem will be much appriciated
thanks mitch
if vinly is cracked - it's done.
you can try to patch.
are you sure it's not a rubber seal adjustent to hte window's glass?
remember tiny leaks always exist in covertible tops.
but if it's more than few drops - then it needs to be solved.
MrVegas
Jul 20, 2014 06:19 PM
