CLUTCH problems
Old Dec 10, 2005 | 05:17 PM
s2000honduras's Avatar
Post CLUTCH problems
hi get my s2k yesterday my car,when i push the acelerator i get slip i dont know the name of this problem ,at 6000 rpm slip the clutch
i need remplace the disk ? pressure plate? bearing
Old Dec 10, 2005 | 05:25 PM
fit 04 clutch disk? n pressure plate? bearing?
let me know thanks
Old Dec 10, 2005 | 05:52 PM
xviper's Avatar
Assuming I understand you correctly, you have a worn clutch that is no longer holding power. When you try to accelerate, your rpm goes up much faster than your car speeds up, yes?
You need to get a new clutch disc, throw out bearing and possibly get the flywheel re-surfaced. If it will not tolerate a re-surfacing (machining), then a new one will be needed and then you'll need a new pilot bearing, also. As long as you're in there, you may as well consider spending a bit more money and put in a heavy duty pressure plate (ACT HD PP is a good choice).
It may be too expensive for the shipping but Hardtopguy has the perfect set-up for a clutch replacement:
http://hardtopguy.com/store/customer/produ...=234&cat=&page=
Old Dec 11, 2005 | 08:50 AM
yes what about only pressure plate with new disc what the best clutch aftermarket where i can buy?
Old Dec 11, 2005 | 08:56 AM
jwa4378's Avatar
ypu can buy from www.hardtopguy.com
As far as an aftermarket disc goes, unless you are running high hp / torque figures, the OEM will do fine. Upgrading the Pressure Plate to the ACT will definitely be a plus. If you indeed want an upgraded disc, I believe ACT makes one as well (Stage 2, I believe).
John
Old Dec 11, 2005 | 09:39 AM
thanks friends
prj3ctm4yh3m
Jun 26, 2011 12:59 PM
keungkeung69
May 16, 2010 06:32 PM
maxspeedsix
Dec 24, 2009 02:07 PM
brian10jones
Feb 2, 2009 05:03 PM
Ron
Jun 2, 2007 01:23 PM
