Clutch Recommendations (from experience only!)
I replaced all of the bolts on my driveshaft. They were already starting to round out. There are two different lengths so make sure to get 6 of each if you replace them.
The glue stuff was probably Loctite. Be careful using it because these bolts are already hard enough to get out.
Originally Posted by DIESELPILOT1969,Sep 15 2005, 07:25 PM
Was there any fabricating to this mod?
if you have ramps it should take you no more than an hour. for me bleeding the line took longer than the rest of it (other than the beer breaks). overall very easy, but for me not much change.
your mileage may vary
on the 00-03, they are two different size bolts, each with a 6mm inset hex head
on the 04-05, they are all 12 the same, each with a 8mm inset hex head
also the shaft diameter increased from 8mm to 10mm (if memory serves) between AP1 and AP2.
back from the dead,
I'm also in need on some advice too, need to replace my clutch very soon, and i am down to just about 2 options,
First of all i have an 04 AP2 with 45K miles. besides a K&N filter and a straight pipe is pretty much stock and i'm 95% sure it will stay this way for a long time
No Track racing at all, Daily driven, just VTEC very often.....
so new clutch needed,
Option 1 OEM Clutch Disk, PP & AP1 FW $534.35 w/o bearings
Option 2 SPEC Clutch Stage 1 Disk & PP & AP1 FW (this setup would cost aprox. an extra $222.10) $756.45 w/o bearings
any input in helping me with this decision will be greatly appreciated
all I can say is that my sound recommendation is to stay away from any SPEC product. Their honestly about the clutch buzz on stage 2 products has been less than sincere ("we don't believe it happens!"). even the boosted guys are having great luck with an OEM honda clutch disc and a ACT heavy duty pressure plate. I think in the most extreme circumstances for you, that's the most you'd need.
Lots of posts here about clutches, and I frankly still don't know what the major differences are on their clutch plates (i.e. the major pros and cons of each).
My mechanic highly recommends carbon plates, but he's used to working with high-powered cars like 400hp+ Evos and M3s ... at the end I went with HTG's combo. My car's still in the shop, and am looking forward to test what the light weight flywheel + ACT PP + OEM disc is all about on a relatively stock CR-wannabe S2K ...
Anyhow, it seems like there isn't really any real consensus when it comes to the clutch, as each and everyone here has a different setup (some are NA , and some have FI). Also boils down to personal preference as well as usage (i.e. 90% track? or 90% city?).
[QUOTE=Ks320,Mar 5 2009, 09:46 AM]Lots of posts here about clutches, and I frankly still don't know what the major differences are on their clutch plates (i.e. the major pros and cons of each).
Originally Posted by gabster,Mar 6 2009, 02:16 PM
KS320 What kind of flywheel do you have?
also Please let us know your feedback when you get your car back.
and yeah i am aware of super light FW aren't great, the lightest i would go with is an OEM AP1
Im leaning towards ap1 FW+ OEM Disc+ ACT PP
My car is 98.5% stock and i would say I use the car 100% on the street but frequent hard driving...
I got the ACT flywheel ... I "think" I have an AP1 flywheel, but I'm not 100% sure. Because I have AP1 gear ratios, but CDV and AP2 synchros and other AP2 goodies on my JDM 2004 AP1. I will weigh my flywheel when my mechanic takes the FW out, and post my experience of the ACT flywheel against whatever FW I had before.
I feel that I have an AP1 flwyeheel on my current car (given that it feels that the revs drop quicker than my AP2 from before), but I'm not entire sure ... will keep you guys posted on how things go for sure
