Clutch slipping? it's fixed!
[QUOTE=HvRRZ,Nov 14 2005, 01:06 AM] Interesting thankx for the information. I began to think about it being the stock pressure plate with the aftermarket parts. Could be that this is the problem, but also this problem began this week. I've been driving around with this set-up for 10K miles and this had never happened before. If this is the problem then great because it'll be a lot cheaper to buy a PP then a whole new clutch
Originally Posted by Cyclon36,Nov 14 2005, 08:33 AM
Well, rule of thumb is to replace the friction disk if you replace any of the other parts. You don't want to go through all the trouble of replacing a pressure plate and reusing a friction disk that could be worn or glazed over. OEM disk is about $80 new.
Originally Posted by HvRRZ,Nov 14 2005, 07:34 PM
Could the flywheel also have damage due to this problem? I hope not.
1. Take it to a shop to get the flywheel turned or resurfaced (not sure if that's a good idea or not with the Toda)
2. Manually "resurface" it by roughing up the mating surface evenly with some 200 grit sand paper (not enough to take down the material, but just enough to take off any disk residue that might be on it).
3. Assume it's not damaged or glazed over enough to matter and just stick it back in.
It doesn't sound like it's really a big deal though if you can slightly feel some slipping. I'd say just rought it up, clean in in a solvent, and stick it back on.
Originally Posted by Cyclon36,Nov 14 2005, 07:20 PM
It might be a bit glazed over, but it's not an issue like the disk would be. There are three ways to approach this.
I don't believe the flywheel will be to bad. The slipping really isn't that bad, and since it started to slip I haven't been driving it hard.
I don't think the Toda flywheel can be resurfaced, but I will manually try it myslef as you said.
Have a family member who's willing to check it for me for free, and even replace it for free, hoping I have time to do it over the weekend.
Once again thkx for all the help guys, and I'll keep this updated once it's taken care of just to let you guys know what exactly went wrong.
thought for those that "care" or give a shit, I'd let you know what's up. Installed the ACT Clutch Kit, and the problem is more then solved. My clutch disk had nothing on it, and the stock pressure plate was burned up due to the slipping.
The ACT clutch is rated to have 30-40% more grippin force, but i'd say it's more like 70-80% lol. This thing gripps like a matha #$@$@er. anyway as for the flywheel, it was in good condition. Nothing wrong with it except it had what looked like two small surface cracks(very tiny areas), but I did a manuel resurface and it looks like brand new. So alls well, and thkx everyone who gave info. Peace
and Happy thanksgiving.
Originally Posted by dyhppy,Nov 23 2005, 07:55 PM
would you recommend the oem friction disc or the ACT? i worry about everyday drivability.
would i recommend it for street use? yes it feels fine as far as me using it for street driving. everyone has there own preference, but it feels very good to use for street driving, plus the added grip it provides is amazing.
Originally Posted by dyhppy,Nov 23 2005, 11:09 PM
i have the ACT PP with oem friction disc. just wondering if anyone can offer a comparison.
thankx
thankx
