Clutchless shift into neutral
yep I have actually saved my own butt before when I was almost stopped in traffic, saw the car behind me was not going to stop in time, floored it and got onto the shoulder more than once. One time, the car behind me stopped about 6 inches before hitting the car that had been in front of me! Had I already been coasting in neutral there was no way I would have avoided that. now, I come to a stop, clutch in and in gear, until I see at least the car or two behind me stop, then I will drop it in neutral to wait for the light to change or traffic to move.
An ap2 flywheel imposes this slower shift cadence. Hence why lighter flywheel is popular upgrade.
Other possible causes: (all except last two related to dragging clutch not fully disengaging)
Improperly adjusted clutch rod
Contaminated clutch fluid (or air in lines)
Improperly greased trans shaft splines (wrong grease, not enough, contaminated, etc)
Crappy exedy or similar clutch disk starting to fail, dropping a spring.
Inappropriate trans fluid, or simply trans fluid old and broken down
Worn syncros
Worn syncros
99% chance it is synchros. If it were the clutch dragging, binding ,etc it would be happening in all gears.
It is kind of odd that it is 5/6 because typically the lower gear synchros get more of the beating.
sam i am
Jul 16, 2013 02:18 PM
FRCHNDN
Jul 6, 2001 02:43 PM
