Cold engine questions...
Old May 9, 2004 | 05:42 AM
TunedS2000's Avatar
Default Cold engine questions...
I mistakenly drove my S2000 past 6,000 RPM and it started to bog down at 7,000ish RPM when the engine temp was at just one bar. I sort of damage did I do? As far as I can tell it still runs the same. I know your not supost to do that to a cold engine but I just totally forgot it was still cold.
Old May 9, 2004 | 07:36 AM
RazorV3's Avatar
you hit the cold engine rev limiter, which is to help prevent you from going past 6k-7k rpm when the engine is cold. that is why it's there in first place as a preventive measure. you didn't do any damage and i hope you learned from your mistake.
don't worry.
Old May 9, 2004 | 12:49 PM
TunedS2000's Avatar
Thanks
Old May 9, 2004 | 09:39 PM
Utah S2K's Avatar
Actually the failure is related to oil pressure or a lack thereof. At low temp the oil is thicker and hence is lower pressure. At "3 bars" the viscosity has improved and the pressure higher.....and the VTEC solenoid will engage.
Utah
dean29
Sep 26, 2008 04:04 PM
Saab9-3
Sep 23, 2008 11:59 AM
Dragon Curve
Oct 15, 2004 04:39 AM
hyun83
Aug 20, 2003 03:50 PM
