cold starts?
Old Nov 17, 2010 | 04:48 PM
s2cho's Avatar
Thumbs up cold starts?
i was just wondering how much trys does it take for your s2k to start?
im in colorado and it gets a bit below freezing.
first try the engine only feels like 2 cylinders are fireing and it shakes like crazy. (
then dies)then second, it starts and goes to 2k rpm and dies
third time the rpm stay at 2k and warms up.
i was just wondering if this was normal?!?!!?!?
Old Nov 17, 2010 | 04:55 PM
2k4NFR's Avatar
Mine does it once before it will start up and run. Started doing it after I installed my giles tuned emanage ultimate. I originally thought that had to do with it but I've read that quite a bit of s owners experience this issue
Old Nov 17, 2010 | 04:57 PM
RedCelica's Avatar
what oil are you using?
Old Nov 17, 2010 | 04:59 PM
hrpfg2's Avatar
ah dont think thats normal...
it shouldn't dies like that.
It gets down to the 30s here and it starts right up every time.
s2cho's Avatar
mobile one synthetic 10w 30
last oil change 700 miles ago
Old Nov 17, 2010 | 05:00 PM
s2cho's Avatar
D: what could it be?
but it always turns on and runs like a champ on the third try.
Old Nov 17, 2010 | 05:02 PM
2k4NFR's Avatar
Mobile 1 full synthetic 10/30 here also changed about 1000 miles ago
Old Nov 17, 2010 | 05:17 PM
RedCelica's Avatar
if it's below freezing Honda (and Exxon/Mobil TSTL) strongly recommends that you switch to 5w-40
https://www.s2ki.com/forums/index.php?showtopic=358505
you might want to try and give it A TINY bit of throttle the first time you try and start the car. Otherwise, it might be electrical.
Old Nov 17, 2010 | 05:25 PM
hrpfg2's Avatar
try leaving the key on the #2 position for a few seconds longer before starting the car. that would give the fuel pump time to prime.
Old Nov 17, 2010 | 06:14 PM
rob-2's Avatar
Could your battery be dieing? Is it struggling to turn over?
