cold starts?
Old Nov 18, 2010 | 05:55 PM
  #21
Suzukuh's Avatar
^ You don't have power steering fluid, and this car has a timing chain not a belt. So don't worry about servicing either of those.
Old Nov 18, 2010 | 05:57 PM
  #22
Bloodred's Avatar
Originally Posted by s2cho,Nov 18 2010, 05:29 PM
and get EVERYTHING tighten lubed and maybe a new timing belt
Good luck with the timing belt
Old Nov 18, 2010 | 07:43 PM
  #23
s2cho's Avatar
sweet? (:
Old Dec 8, 2010 | 07:38 PM
  #24
2k4NFR's Avatar
Dont mean to bring this thread back but just saying its very possible it could be the fuel in your area. In oklahoma my car did the same thing as yours on cold start and I drove home on leave to indiana and its a hell of a lot colder here and it starts like a charm every time and I haven't changed anything
Old Dec 8, 2010 | 09:00 PM
  #25
s2cho's Avatar
oh i found that leaving the key in the #2 postion for about 30 secs and
then turn the car on. it works fine now haha
i think its cause im parked on a lincline and the fuel has to travel up
Old Dec 9, 2010 | 04:53 AM
  #26
JLUDE's Avatar
Originally Posted by hrpfg2,Nov 17 2010, 06:25 PM
try leaving the key on the #2 position for a few seconds longer before starting the car. that would give the fuel pump time to prime.
THIS!
It is more difficult for the fuel system to build proper pressure when its' below freezing.
Turn the key to ON for 5 seconds before pushing the start button.
Old Dec 9, 2010 | 01:32 PM
  #27
s2cho's Avatar
Originally Posted by JLUDE,Dec 9 2010, 05:53 AM
THIS!
i try that and my car starts and shakes as its on 2 cylinders
and when it turns on it seems like a belt screeches.
but a little rev to 3-4 makes the sound go away
Old Dec 9, 2010 | 01:55 PM
  #28
berlinablackie's Avatar
JLUDE and 'hrpfg2' are correct. And whoever else said to give it just a little gas. My car requires this cold weather starting method. I vote its normal because I don't know any different.
Old Dec 10, 2010 | 04:51 AM
  #29
wittman's Avatar
i triedputting the key in and letting it set for 5 seconds and it worked perfect
Old Dec 10, 2010 | 05:31 AM
  #30
JLUDE's Avatar
The incline shouldn't cause a problem unless the fuel tank is really low on gas. The system is under pressure so an incline makes no difference.
