contemplating buying an s2k, have some questions
Old Dec 5, 2002 | 06:02 PM
JsnS2k's Avatar
Default contemplating buying an s2k, have some questions
I am interested in buying an S2000 (MY 00-01) when spring rolls around. However I am concerned with the following issues:
-Transmission
-Differential
-Clutch
-Rear axle
The car will more then likely have the occasional drop from 6,500-7,000 rpm's. Hopefully I'll have the chance for some tracking as well as the usual mountain drives.
Although I've wanted to have an s2k for quite some time now, its not a practical option if I have to constantly worry about the following issues. Thanks for your insight.
- Jason
Old Dec 5, 2002 | 06:05 PM
Destiny2002's Avatar
I feel you shouldn't get one, that is if you "worry".
However, there is no guarantee that another car you buy will hold up any better under repetitive abuse.
Old Dec 5, 2002 | 06:22 PM
JsnS2k's Avatar
What you said is very true. However, the E36 M3 for instance will not need to be dropped from 6,500-7,000 in order to get the same results. And there are no problems being reported such as the transmission and so on.
And no, I am not only interested in drag racing what so ever at all. But I know it will happen on occasion and it does need the high drop to get the best performance.
Also I have herd stories of transmission failure without any abuse to the car.
I am very interested in this car. I love it every bit, I just don't want the head aches.
Old Dec 5, 2002 | 06:33 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
buy a 2002 if your that nervous. earlier bugs have been worked out.
Old Dec 5, 2002 | 06:37 PM
JsnS2k's Avatar
Don't have enough money. I am paying cash for the car.
Old Dec 5, 2002 | 06:38 PM
speed4tu's Avatar
I have not ever had any trouble with any of the parts you mentioned, however I have not ever done drops at 6500-7000 RPM. If you do enough drops one of the things you mentioned are bound to break
Old Dec 6, 2002 | 08:14 AM
brushman's Avatar
Grasshopper:
If one drops anything enough..does it not usually break?
If your are nervous, then maybe you should not buy one. You will always be driving around trying to convince yourself that something is wrong. IMHO
Electrichink
Aug 14, 2006 07:45 AM
Naz20xl
Jun 3, 2006 08:22 PM
rennfahrer
Oct 18, 2004 05:04 AM
cet001
Apr 22, 2004 08:25 PM
vdozer
May 7, 2001 04:25 PM
