Cooling plate
Old Feb 28, 2007 | 12:32 PM
  #31
Jsmply's Avatar
Originally Posted by neveronlines2k,Feb 28 2007, 03:26 PM
I haven't yet, but I am planning too .
I have an FIPK kit and an ARC plate (no scoop but still lets cold air in the bay near the filter) I am stil playing around with where to locate/route everything, but I am planning to run about a 2 to 2 1/2 inch flex hose from the grill or faux vent up to the bottom of the FIPK kit and dremel a hole in the bottom of the box to mount the hose to this should have the same effect as a ram air intake and maintain the CARB# (my goal is to make the modifications as discreet as possible )
Do you think enough air will travel upwards in that type of setup and into the bottom of the box to actually make a differance?
Old Feb 28, 2007 | 12:33 PM
  #32
Jsmply's Avatar
Originally Posted by dolebludger,Feb 28 2007, 03:38 PM
If the ARC plate has no scoop, how does it make cool air avialable to the filter and intake?
There have been some mods done using the AUT plate (with the scoop) and a K&N FIPK. I don't know how well they work. Might be quite nice. However, note that the FIPK set-up dies not seal the filter in a box like the stock unit. Whlie the AUT could just blow in cool air, there is no possibility of putting the aribox under any positive pressure from ram air, for lack of this seal.
Well theoretically the K&N FIPK does make a seal with the rubber on top of the box that supposedly makes a tight seal with the hood. In my experiances, that stuff falls off though, I doubt its making any kind of seal in most applications.
Old Feb 28, 2007 | 12:34 PM
  #33
neveronlines2k's Avatar
At speeds it will work . Similiar to how brake coolers work.
Old Feb 28, 2007 | 12:47 PM
  #34
shotiable's Avatar
the rubber for the kn fipk is supposed to make a seal? i didnt know that? i thought anything touching the hood would rub up against it and have signs of ware... just like how one of my kn hoses rubbed up against the underside of the hood
Old Feb 28, 2007 | 01:00 PM
  #35
Thats why they put the rubber on it, but I am not convinced it seals at all. Mine I know does not seal cuz it fell off during installation
The ARC plate does not have a scoop but the vents for the air are in on the same side as the filter. Granted the benifit will not be as great as with a scoop but it still helps.
Old Feb 28, 2007 | 01:08 PM
  #36
dolebludger's Avatar
If the FIPK seals (or sort-of seals) to the top of the hood, I can't see any benefit from either a "scooped" or "unscooped" rad plate. It just wouldn't increase airflow to the filter enough to bother with.
It has been my impression that thge FIPK is designed to draw its air from the hole in the pax side internal fender well. There is cool air available there, and mu mod based on the AUT draws air from this sourse also, in addition to the "over the radiator scoop."
But I just can't visulize how any kind of rad plate would help the FIPK do its job better.
Old Feb 28, 2007 | 01:15 PM
  #37
Jsmply's Avatar
Dolebludger, it seals on 3 sides, the back, left, and right. The front is still open. I think the design is to force the air from that area and not from the sides where heat can leak in from the engine.
What does everyone think of neveronline's tubing into the bottom of the FIPK container idea?
Old Feb 28, 2007 | 02:44 PM
  #38
AlX Boi's Avatar
So if the plastic plate is removed, wouldn't the air that was supposed to go to the radiator be diverted away? If there's absolutely no problem, the why was there even a plastic piece there?
So I think the noobs need a pros & cons chart for removing the plastic plate. Could some list it?
Old Feb 28, 2007 | 02:56 PM
  #39
If the FIPK is open on its front edge, then a rad plate like the AUT that has a scoop would be of benefit. The AUT would supply cool air to the filter, but not under pressure, of course. I'd have to see a pic of the ARC rad plate to form an opinion on whether it would help or not.
With the FIPK, I think it would be beneficial to run a 3" industrial flex hose into the pax fender well (it'll fit) and down to the cut-out of the pax side fake vent. It would be a PIA job, as you'd have to remove your pax fender. Then, you'd have to fabricate a funnel-like piece to mount inside the cut-out onto which the 3" hose could secruely fasten.
If the CF rad plate has a CAI scoop, a reason for removing the stock plastic piece would be that the CAI wouldn't work with that piece in place. If the CF rad plate has no CAI scoop, the purpose of removing the stock piece would be to allow freer access to air by the radiator. That is the ultimate purpose of those "scoopless" rad plates.
Old Feb 28, 2007 | 03:26 PM
  #40
my point was just that the little bit of air the vents let into the engine bay are better than nothing at all. I was not trying to say it was as good as the BYS/AUT scoop style rad plates.
3 inch would be a little big for my application (though they would be a better benifit) AP2 fake vents are smaller than the AP1's thats why I was going to use 2-2 1/2 inch. I want it to look as clean and understated as possible while still being functional.
