Corbeau Carrera Seat Fit?
Anyone happen to know if this seat will fit in the S??
http://www.corbeau.com/brochure/carrera.html
They sell mounting brackets for $87 bucks or so for the S2000. I have heard good things about this company, it may be a less expensive solution for a racing seat. Any opinions??
I am concerned about seat height also, the padding on the bottom looks like it may be a little thick.. (my head is over the roll hoop )
Chris
Chris
the shoulder points will fit, the base will not.
also keep in mind if you could get this seat to fit, it would act as a high chair - because of the bottom mount, and the adjustability would be nil because of the slim fitting - you couldn't get your hand on the rotory dial adjuster and if you could, it probably wouldn't be able to turn.
if you are interseted in a Sparco Roadster seat with a custom seat rail, I can help you out. Yes, its more expensive, and it takes more time to get, but it will be worth it, and save some weight. =)
