Could this be a more serious problem in disguise?
Old Jan 4, 2001 | 11:06 AM
jalford's Avatar
My battery is dead after spending six consecutive days undriven in below-freezing temps. What alarms me is that it won't even jumpstart. Everything lights up, but I just get a series of rapid clicks when I hit the start button. My friendly neighborhood Honda service department says I might have to charge the battery for four hours before it has enough power to start the engine. I did not leave my headlights on, so it seems a little strange to me that my battery would be THAT dead. Am I imagining things, or is there a potentially more serious problem here?
Old Jan 4, 2001 | 11:09 AM
Argetni's Avatar
Very common for Hondas
(at least Civics, Integras and S2ks, which all have the same battery). Have you ever seen a battery so small? Most motorcycle batterys are bigger.
Old Jan 4, 2001 | 11:11 AM
meat's Avatar
Banned
I hope mine starts - its been in the garage for about 8 weeks with no start-ups.
I left mine for weeks at a time with no start-up last winter with no problem. Are you sure you didn't leave the lights on anything to drain the battery?
Old Jan 4, 2001 | 11:14 AM
jalford's Avatar
I'm sure I didn't leave the headlights on. It is possible that I left the cabin light on, but I seriously doubt it. Is there anything else that can draw power when the keys are not in the ignition?
Old Jan 4, 2001 | 11:24 AM
funcar's Avatar
If you are going to store your car you should disconnect the battery.
You will have to reset the code in the radio but at least you won't have a dead battery.
Old Jan 4, 2001 | 11:25 AM
funcar's Avatar
but then again 6 days it shouldn't be dead
Old Jan 4, 2001 | 11:30 AM
JRM's Avatar
JRM
Did you leave your alarm on all that time?
Old Jan 4, 2001 | 11:33 AM
jalford's Avatar
Yes, my alarm was armed the entire time. Do you really think that it would drain the battery?
Old Jan 4, 2001 | 11:44 AM
CG's Avatar
CG
[QUOTE]Originally posted by jalford:
[B]Yes, my alarm was armed the entire time.
Old Jan 4, 2001 | 11:46 AM
David's Avatar
It was probably your alarm. I remember someone else around here with the same problem. I've gone two to three weeks without starting it and it started everytime on the first try.
