Crunchy gears
Old Dec 13, 2009 | 10:00 AM
s2k_mh's Avatar
Default Crunchy gears
Hi i had my s2000 for abt 5 months now, and the gears have been quite crunchy especially on 1st n 2nd. Does any1 know wat da problem is and how to solve it?
Thank you
Old Dec 13, 2009 | 11:15 AM
PJCC's Avatar
Define "crunchy".
Old Dec 13, 2009 | 11:16 AM
Terror's Avatar
It's quite normal for your car to feel somewhat "notchy". On cold days, it can be even worse.
If you are unsettled by it, change your transmission fluid to New Honda MTF, for peace of mind.
"Crunchy" on the other hand, may be a different story.
Old Dec 13, 2009 | 11:28 AM
alSpeed2k's Avatar
When the car is cold, try taking your time to shift between gears, it might help a little.
Old Dec 13, 2009 | 01:45 PM
zeroptzero's Avatar
mine was like that when I bought it two months ago. Here is what I've done to eliminate my problem:
Changed tranny fluid to new Honda MTF. Lubricated the shifter as per the TSB. Adjusted the clutch rod a bit longer to assist with the timing of my shift/clutch engagement point. The tranny now shifts as good as new.
I also swapped the clutch fluid and lubricated the slave cylinder, these weren't affecting the shifting but it is good maintenance to do on a used S2K.
Old Dec 13, 2009 | 04:38 PM
s2kftw's Avatar
ive had mine for about 7 months now, and mine has started to do some funny things, and i've found the clutch master cylinder is slightly leaking, so mine will be getting replaced soon, along with the tranny fluid.. which everyone here recommends
Old Dec 13, 2009 | 05:10 PM
s2krdstr's Avatar
don't know if this will help but here it goes : https://www.s2ki.com/forums/index.php?showtopic=275203
dougcee
Dec 13, 2010 04:40 PM
cvedral
Nov 6, 2008 02:23 AM
00blackap1
Sep 30, 2008 04:13 AM
BowlofRice
Apr 10, 2007 05:41 PM
klee1113
Mar 20, 2007 10:50 AM
