Daily Driving Manual Tranny Tips
I am looking for tips on how to be a better manual transmission driver while daily driving my S. Can you guys offer what you have learned over the years? Here are some from me:
- When at a stop, put the car in neutral gear instead of pressing on the clutch and holding it in.
- Do not rest your hand on the shifter when the engine is on
- Do not rest your foot on the clutch pedal, use the dead pedal
Also, this has been at the back of my mind ... when approaching a stop, is it better to downshift to each gear or is it ok to coast to neutral until you reach your stop?
Don't skip gears.
Downshifting and rev-matching upon deceleration is generally an ideal way to decelerate. This keeps you in control and the ability to accelerate in an instant in case of some sort of emergency.
Originally Posted by TheCarGuy2021,Dec 30 2007, 02:43 PM
Don't skip gears.
Skipping gears for downshifting is OK (with a rev match). Dont skip going up gears though as others have had problems in the transmission because of it. . .what the exact problem is, I dont recall.
I normally coast up to lights/stop signs with the clutch pedal in but still in gear, so I can shift if needed. Once I get to the stop though, into neutral it goes until I see the other lights change to yellow.
Originally Posted by nightcrawler7188,Dec 31 2007, 03:40 PM
don't force or slam the shifter into gear--quickly get it to the position right before clicking completely in to gear and then apply constant gentle pressure until you sort of feel the shifter pull itself in.
i dunno what would happen in my S,
but when i was in a spirited run in my n/a MR2 (
)i disengaged the clutch, pulled it out of second, then slammed it right into third.
i broke my right shift cable. lol.
something i learned is to not let the clutch out suddenly with a shift.
it reduces that shock and jerk. dun do it slow like you're starting from a stop of course,
but put a little hesitancy in the release so that the transition is a little smoother.
stops people from banging heads ;p
i totally mastered this in my MR2... but i can't seem to do it as well in the S
but if you're in a spirited drive mood, hell disregard that.
Originally Posted by ROTFLMAO,Dec 31 2007, 11:44 AM
So if you are driving at say 40MPH in 4th gear, while you are braking, you should be downshifting while revmatching to 3-2-1-Neutral then stop? That's a lot of effort
