Defroster Q?
Old May 13, 2004 | 04:50 PM
SilverKnight's Avatar
Default Defroster Q?
Used the Defroster for the 1st time the other day. So the AC has to be on for this to work? It was like 65 degrees but raining, so my windows were down and the inside got fogged up. Tried to use defroster with no AC and it didn't work to well and the fog stayed the same. Then with the AC on the deforster worked perfect. I try not to use the AC that much and my other cars could use the defroster perfectly with out the AC. Am I doing something wrong? Maybe the temperature knob should be at a certain level?
Old May 13, 2004 | 04:52 PM
ttb's Avatar
ttb
can't help you but in general defrost works better with the dry ac air.
Old May 13, 2004 | 04:57 PM
Yeh I know but it seems liek the deforster is way weak(not clearing up the fogginess fast) in the s2000 without the AC.
Old May 13, 2004 | 05:10 PM
MattG's Avatar
Air con in general removes humidity from the air. I always use cold air on the windscreen to defrost it in cars.
Old May 13, 2004 | 05:12 PM
KenS2K's Avatar
FYI: AC = Air-Conditioner. Not Air-Cooler.
The AC is primarily a dehumidifier. The cooling process was only a bonus by-product of the invention. Your defroster settings will work best with the dehumidifier turned on.
Old May 13, 2004 | 05:54 PM
dhayner's Avatar
Yes, turn the heat up. It's not that complicated.
Pointblank
Feb 2, 2009 04:05 PM
xman
Aug 28, 2005 08:08 PM
Zeemz
Jun 28, 2005 11:51 AM
YellowS2kPwr
Jun 9, 2005 10:54 AM
scooby2
Jan 25, 2002 05:24 AM
