Diff fluid
Old Jul 13, 2022 | 10:35 AM
  #31
cosmomiller's Avatar
Top Answer: 1
Originally Posted by azn akira
75W90 is thinner so you'll have less drivetrain loss but our diff capacity is pretty small at about 0.7 quarts so it is going to get pretty hot. It is probably fine if you don't track or auto x at all but at the track I'd want something thicker which is why I run 75w140.
I use 75w-90 Mobile 1 a la Billman. However, I change it every year. Why? Because I can and it is a great excuse to fart around in the garage with the dogs. It keeps the oil fresh and up to standards. I also change out the transmission fluid to boot. I use Amsoil for that.
Old Jul 14, 2022 | 09:09 AM
  #32
teckert's Avatar
Originally Posted by troubleshooter
For our diff, it should be 75/140 as long as the oil has friction modifier in it. There’s AMsoil, Motul, Eneos and Redline top brands.
@troubleshooter I thought there wasn't a need to have friction modifier in it? I've read it wont help but it also wont hurt.
Old Jul 15, 2022 | 06:46 AM
  #33
Mr.Matchbox's Avatar
It´s a Torsen differential, therefore it dont need Friction Modfier. But it dont hurt if the oil contains Friction Modifier.
https://torsen.com/faq/
From the Page:
How do a torsen Differential works?
It’s actually quite simple – by creating friction. Friction within the gearing is what resists wheel slip. When torque is applied to the differential, it generates thrust forces on the gears. The gears, in turn, push against the inside walls of the differential case, and that produces friction. In short, the more torque is applied, the more friction is generated, and the more resistance to wheel spin there is. See How it Works on this website.
Billmann has posted Pictures here, he found the "Ears" of the friction disks that hold them in Position at the side ot the Differential sheard of. They come out of the differential while changing the oil.
Sheard of by.... to much Friction?
s2kking
Jan 16, 2014 06:25 PM
macdaddies911
Feb 13, 2012 08:01 PM
lukas2k
Nov 29, 2007 05:29 PM
spectacle
Jun 16, 2006 12:30 PM
