Differential issues
Old Nov 22, 2007 | 08:56 AM
lukas2k's Avatar
Default Differential issues
I'm looking for some advise, and perhaps a honest answer about my rear diffential. It makes a whining noise when i make a slow sharp turn, mainly when i'm starting out and turning. I took it to my dealership and they replaced the differential fluid, which was black I heard them oversay. Then they proceeded to tell me that the noise was normal when doing lock to lock turns. I just can't believe that it's normal to have the whining noise. My car is a new 07 and has 1,500 miles on it.
Old Nov 22, 2007 | 09:46 AM
s2k dre's Avatar
when i bought my my04 it made a little whinning noises on u-turns only in 2nd gear. And i got 64k on my car now and i changed the fluid at 35k and at 60k, and no other problems besides the little whinning on u-turns thats all.
Old Nov 22, 2007 | 06:53 PM
Saki GT's Avatar
Try and post a video of the whining noise, but I don't think you have anything to worry about. Also, this should be in S2000 Talk, so moving...
Old Nov 22, 2007 | 07:11 PM
S2KPUDDYDAD's Avatar
Did you ask what fluid they used to replace your old fluid? Some Honda service techs have made the mistake of using the wrong fluid.
Old Nov 22, 2007 | 07:25 PM
negcamber's Avatar
Post in the Carolina or Atlanta forum on s2ki and have a local owner listen.
Old Nov 22, 2007 | 07:47 PM
Mrfixit687's Avatar
my 07 does that, its normal, this is a sports car so it will have some sports car noises, its not a lexus
Old Nov 22, 2007 | 08:11 PM
airgate's Avatar
LOL...this is soooo DejaVu...
https://www.s2ki.com/forums/index.ph...&f=48&t=544954
Old Nov 23, 2007 | 12:59 AM
TestaRossa's Avatar
Old Nov 23, 2007 | 04:17 AM
FISH22's Avatar
Right...Sports car noises.
Most likely you are hearing the LSD at work. In tight slow turns, one wheel is moving faster than the other, and this makes the LSD lock up. I've had a faint groaning sound that was coming from my 06 at slow turns, but it went away after putting some LE 607 in the diff.
Old Nov 23, 2007 | 05:25 AM
lukas2k's Avatar
What is the correct differential fluid to put in the s2k? I think I'll start with that since I don't think my dealer replaced it with the correct one.
