do I need to change thses fluids.
Old Sep 14, 2004 | 05:20 PM
Scablander's Avatar
I have a 2001 S2000 and the owners manual says to replace the brake fluid every 3 years. Clutch fluid replacement is not mentioned, but since it is the same fluid, I did both. Honda recommends DOT 3 fluid for both the brakes and the clutch.
Old Sep 14, 2004 | 05:41 PM
s22k's Avatar
if you want to keep your brake system in top condition, you should consider changing your brake fluid at least every couple years. over time, moisture will find its way into the brake system, which can lower brake fluid boiling point and reduce braking effectiveness. i usually bleed my brakes every other year, it's a 30 minute job and costs almost nothing. hope this helps.
Old Sep 14, 2004 | 08:31 PM
TunedS2000's Avatar
bump...
shumax
Feb 27, 2012 04:16 AM
Starbrd
Jul 4, 2008 09:11 AM
fromthegut
Jan 2, 2007 08:43 AM
TRDLiquidSilver
Jun 7, 2006 03:15 PM
johninator
Apr 24, 2004 09:19 AM
