Does an S2000 really spin/crash that easy?
Originally Posted by riceball777
Compared to all my other cars I have owned I would say yes the s2000 is very easy to crash. I have owned an 500whp integra and a 500whp evo 8. I have auto crossed all the cars and the integra and evo they are almost impossible to spin out. When your going to fast or give to much throttle or the boost comes on to say the car just pushes and under steers. With my s2000 it handles amazing but when taking turns at 10/10 it's always on the verge of spinning out. When pushed to hard instead in of just pushing the back end will kick out and it will start sliding around.
I also own a bmw 335i which is rwd just like the s2000. And yes the s2000 does Handel much better but the s2000 is also much Easyier to spin out in.
Strangely I have never had lift off oversteer in my S2000, or even in the Formula 1s & Formula 2s I raced for years. In fact in all of them, easing or even lifting off the throttle has always brought the tail back. Nothing would of course bring it back if I had exceeded the limit, even in front wheel drive things, that have promoted this clumsy form of driving.
I have experienced the happy tail of my S2000 many times. I used to commute in it sometimes, through the mountains, where an early morning shaded patch of damp on an otherwise dry road, or a patch of frost not yet gone, would send the Hondas tail off on a little jaunt, but never viscously. It was no more troublesome than my sedan or Hilux ute on the same run.
The thing that does make the S2000 dangerous for the inexperienced is the steering. It is so light & quick, & the car is so responsive to it, that overcorrection with opposite lock will have the car snap back the other way to the first slide, usually much more viciously than the first slide. Inexperienced rear drive drivers will often throw huge amounts of opposite lock, cause the car to flick back, & leave the scene backwards, on the inside of the corner.
The other thing not mentioned is the age of the tyres. No matter how good when made, by 4 years old, tyres are way past their best. You might as well have the cheapest imported ditch finders on the car by 5 years. A tyre OK on your sedan is just not good enough for a car so responsive to throttle, & steering input.
Treat your S2000 to good young rubber & geometry, & it will be a kitten for you. Just don't be ham fisted with it, it is not a lumpy SUV. Don't go overboard for this slow in fast out either. It leads to excessive throttle application at the wrong time, & is part of the ham fisted driving no S2000 will accept.
I have an AP1 and the rear is definitely prone to snap oversteer, make sure you buy a much stiffer front sway bar, also do not do what I did and take out the stock springs and replace them with lowered springs. If you're going around a corner and you hit the bump stops you will lose the tail end, and if you're an unexperienced driver like myself you will be in trouble again.lol
On my first track session I came off the track SIX times, yes SIX times.
My car is off the road, I am putting a stiff front sway bar on, new tyres, new suspension etc...
I was surprised how easy to drive the S2000 was when I got mine. I came in thinking it was going to be a hairy ride too based on all the comments about the car. But I do have to say that you need quick hands if the car unsettles at the limits. I suppose that's pretty normal for a shorter wheel-based car.
By the way, I keep seeing this car being referred to as a mid-engined car. Regardless of where the S2000's motor is in relation to the front wheels, the car does not handle like a "mid-engined" car where the motor is behind the driver. I've owned a Cayman, and I've also had extensive seat time in the Audi R8. For all intents and purposes, this is a front engined car. Suggesting it is anything other than that is rather silly.
For a long time, the term 'mid engined' was synonymous with mid-engine rear, as there simply weren't many mid engine front cars to be discussing the handling traits of. If you said mid-engined, you almost always meant engine behind driver. No one bothered to say mid-engine rear, so it was easy to think mid-engine always meant mid-engine rear.
But just because a term is often misused, doesn't make its original definition null.
Sent from my SM-G920P using IB AutoGroup
Originally Posted by Car Analogy
For a long time, the term 'mid engined' was synonymous with mid-engine rear, as there simply weren't many mid engine front cars to be discussing the handling traits of. If you said mid-engined, you almost always meant engine behind driver. No one bothered to say mid-engine rear, so it was easy to think mid-engine always meant mid-engine rear. But just because a term is often misused, doesn't make its original definition null. Sent from my SM-G920P using IB AutoGroup
LoL, so much bullshit in this thread.
I'd bet money that anyone who has spun the car in a straight line either broke the rears loose without expecting it or was riding or almost riding the bump stops and hit a significant bump.
This car is no more spin happy than any other rear wheel drive car with a neutral balance. Get a good alignment, get good rubber, and go spend time driving at multiple autocross events.
^^^100% agreed. I've spun my car a lot [at the track], but it's because I overdrove the car and made a mistake. Don't blame the car for a loose nut behind the wheel
So... In order to have this "grip machine" you speak of...
a) what tires?
b) what are the exact alignment specs?
Originally Posted by F1 S2K' timestamp='1458001776' post='23908565
[quote name='RedCelica' timestamp='1457986369' post='23908301']
Hence why I run minimal toe. The s2000 is a grip machine with the right tires and alignment.
a) what tires?
With my AP2 I dialed in a lot more front camber (-1.8) and less rear toe (.16 total), it was great. With an AP1 you want a little less camber up front and a little more toe in the rear.
Now once you get real comfortable there, a non-staggered setup on 17x9" wheels and a large front sway bar is the natural next step. You can really get a lot more usable camber out of the car and the grip is simply amazing. Once you go square you never go back.
[/quote]
Not that I totally disagree with the notion that tires are helpful, but sorting issues prior going to much softer rubber(and the higher speeds and hidden mistakes that come with them) is smarter. sorting those issues, then going to 17x9's only help the car oversteer more resulting in sorting more issues. The joy to the 17x9 setup is the addition of more front rubber, my car came with a 6.5" front wheel and 205s in front. adding 2.5" of wheel and 50mm of tire certainly helped the front, but with no other changes made the rear want to come around it. After sorting it out, I wouldn't want to go back, but only because I'd have to deal with an understeering S until I sorted it out again.
