door problem
Old Feb 14, 2006 | 06:33 AM
jav8or's Avatar
Default door problem
i have searched and have only found one person with a similar problem as mine.
my drivers side door seems to be about and 1/8 of an inch lower than where it should be.
before you ask, the vehicle hasnt been in an accident, the frame isnt damaged, and all vin numbers match.
the question i'm asking is, where can i get instruction on how to remove the drivers side quarter panel ( i think thats what the panel in front is called!) so i can see what the door hinge bolts look like.
Old Feb 14, 2006 | 09:49 AM
vtec9's Avatar
Is the door misaligned when closed? Is it difficult to close? If you lift on the door while closing, is it easy to close? If you answered no, yes, yes I think the door is sagging. Most likely someone leaned on it while open causing the hinge to bend. I have no idea how to take the door panel off though so I can't help you there.
Old Feb 14, 2006 | 10:12 AM
jav8or's Avatar
[QUOTE=vtec9,Feb 14 2006, 10:49 AM] Is the door misaligned when closed?
Old Feb 14, 2006 | 07:56 PM
jav8or's Avatar
i guess no one has any solutions huh............
Old Feb 14, 2006 | 09:36 PM
C4SxM5's Avatar
r u talking about the front fender? if so, there are bolts at the edge when you open the hood, a few more on the bottom where you lift the car and 2 or 3 more from the inner door. not sure how this will help your problem though???
Old Feb 15, 2006 | 10:40 AM
jav8or's Avatar
problem solved . took it to the body shop
im happier now
Old Feb 15, 2006 | 12:08 PM
r_duff's Avatar
what was wrong with it?
Old Feb 15, 2006 | 08:08 PM
kempster's Avatar
i have the same problem, door just looks like its not closing all the way, i brought it to the dealership and its good as new
Old Feb 15, 2006 | 10:47 PM
WPS's Avatar
WPS
im happier now
what did they do?
Bigchief
Apr 13, 2014 07:32 AM
jvrabel
Nov 29, 2009 08:35 AM
s2konroids
Jun 1, 2009 03:18 AM
RL428
Dec 6, 2008 06:03 PM
killereclipse
Apr 22, 2007 06:50 PM
