Driver's side rear wheel super hot...
Originally Posted by CKit,Jul 4 2007, 02:47 PM
You will find many issues with this car that you don't have with your 00 Accord. If you keep comparing, you'll be disappointed!
And don't forget to check the oil level every ~2000-3000 miles (or more) even though you NEVER had to with the Accord.
Total cost for either: Maybe ~$300-500? Just ballpark estimation. Definitely less than $800.
So I brought it to a local mechanic and he said that it was the calipers freezing. He also said that if it was the bearings/hub, that it would makes noises. I didn't notice any noises, so it probably is the calipers. Funny thing is, today after some highway cruising to a friend's house, the wheels were not hot anymore, but just warm. I think it got unstuck somehow during the drive. So, I'm just going to keep an eye on it and if it gets stuck again, I'll have it replaced.
Originally Posted by neoarroyo,Jul 4 2007, 06:30 PM
Will seized calipers/sliders cause that kind of heat on the alloy wheels? I
I agree the causes are a brake issues causing the pads to drag on the rotor without releasing, or a bearing/hub failure.
Keep in mind, if the heat was as bad as described, if it was only a brake issue, chances are extremely good the bearing has been abused to a point where it will fail and if not replaced could indeed end up damaging the hub. The reason I say this is because I just got done replacing both rear wheel bearings and hubs. It seems the constant high heat loads of so much track driving caused the bearing grease to run out past the bearing seals, then the bearings ran without the proper amount of lubrication and by the time I was able to detect the problem the bearings had already scored the hubs...
I had an OLD Capri with a bound up master cylinder that resulted in both front brakes dragging. I figured this out on a very dark night when I noticed my rotors glowing after a long freeway drive. The wheels were steel and were so hot that I could not touch them to remove the lugs to check the brakes. Dragging brakes cause a huge amount of energy disapation and could more than account for your hot wheel.
I think the consensus is the caliper/brake assembly at this point, but the problem disappeared, so...I'll just keep driving it till it comes back and then I'll have both rear caliper/brakes replaced. Thanks everyone for your help.
Ever seen the Boeing 777 take off abort test? They load it to max take off weight and just before it leaves the ground the slam the brakes with no thrust reversers. Long story short....the test was called a success but all the brakes were on fire and tires melted within minutes....cars can exhibit similar problems if someone doesn't realize the problem on the highway.
http://www.youtube.com/watch?v=l5N2uBqJbVU
shwinkwhite
May 16, 2013 06:44 PM
video.
