Driveshaft Spaces
Old Aug 29, 2006 | 09:53 AM
iDomN8U's Avatar
Default Driveshaft Spaces
Are Driveshaft spacers needed for a lowered car?
Drivespaces (from A&J)
Thanks
Old Aug 29, 2006 | 10:10 AM
xviper's Avatar
I see them as "recommended" rather than "required" in all cases of lowered cars. By lowering the car, you'd altered the angle of the 1/2 shafts from where they normally sit. This changes the contacts points in the CV joints and sometimes can create a new and odd wear pattern that may result in the typical CV joint vibration on acceleration. The spacer try to maintain the same contact points within the CVs. Some guys have gone a long time and have had no problems. Some have not been so lucky.
Old Aug 29, 2006 | 10:22 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
No problem,on a moderate drop;(+/- 1 inch).
If you "slamm " it,then...you're looking for trouble...
Old Aug 29, 2006 | 11:29 AM
innovation's Avatar
even if you're lowered by 1/4" its recommended.
Old Aug 29, 2006 | 11:35 AM
gomarlins3's Avatar
I haven't fully decided yet. If I change out the diff again, then I might get them since the install would happen when the diff was put in.
JimmyB
Jul 11, 2008 06:42 PM
S2KBreaker
Jun 5, 2007 10:52 PM
05berlinas2k
Oct 14, 2006 04:46 AM
negcamber
Jun 24, 2006 03:56 AM
FormerH22a4
May 24, 2006 12:48 PM
