Driving during the winter
Old Dec 13, 2017 | 12:32 AM
  #31
Adrenalize's Avatar
Originally Posted by ishtori5
It is your car and you do what you want with it but I still cringe at the thought of driving the S2000 through winter salt.
I feel the same way. If you can avoid winter driving your S2000, do it. A cheap reliable beater car like a another Honda or Toyota can do the winter driving instead
Old Dec 13, 2017 | 08:22 AM
  #32
Nibreezy's Avatar
It’s doable driving here in Virginia. I only drive the s when the roads are completely dry.
Old Dec 13, 2017 | 09:45 AM
  #33
Chuck S's Avatar
Just today. Winter driving bites again. No location but my wild guess is Pennsylvania judging from no front tag and centered stickers in the windshield.
Locals here in Richmond are constantly warning about Black Ice. Too cold for my S2000 even here right now.
-- Chuck
Old Dec 13, 2017 | 09:51 AM
  #34
rudyy's Avatar
I do plan to dry it on a warm sunny day but will also commit to wash the car thoroughly after the end of driving to get all the road salt off. So, it really has to be very warm (above 40F).
Old Dec 13, 2017 | 12:42 PM
  #35
Champ209's Avatar
-- Chuck
I'm pretty sure he's in VA, just next door to me. I told my cousin who has the S as his only car to be very careful and avoid driving it if possible.
Old Dec 13, 2017 | 02:40 PM
  #36
B serious's Avatar
lol...are you guys serious?
Its not very hard to drive a S2000 in winter. I mean...I don't drive mine out of vanity. I've driven (other peoples') S2000's and Miatas in the snow.
Its not a F40 or a car that's mythically difficult to drive. If OP isn't worried about rust, he'll need to use common sense and he'll do fine. He's not even planning on driving in the snow.
It makes like 6LB-FT of torque unless you put your foot through the carpet long enough to reach 6000-9000RPM.
Old Dec 13, 2017 | 03:10 PM
  #37
Hfreak's Avatar
Only 6LB-FT?
Damn, I drove an 87 RX7 that must have made only 5LB-FT for a couple winters in my younger days without wrecking it. Any RWD sports car is terrible in the snow and must be driven with consideration of weather conditions no matter what tires you have.
Old Dec 13, 2017 | 03:27 PM
  #38
starchland's Avatar
Originally Posted by Nibreezy
think it’s better to get a shop that deals with anitique cars and taking care of cars that are in storage do this. They’ll probably have better tools to get rid of the rust 100% and seal it with a stronger coating than your average spray found in the stores.
the idea is to spray the oil before the rust gets a chance to set in. Inspect once a year and reapply as necessary. Nice thing about the oil spray is that it will coat everything including brake/fuel lines. Yes, this would be a like a final coating on top of the POR. The real key to the oil is the seeping action. Around here they may as well pave the roads with salt.
a few observations: if your going to pull your wet, salty car in and out of the garage on a daily basis, your better off leaving it out on the driveway frozen rather than letting it thaw out every night.
If your not going to oil spray your vehicle professionally, at least grab a few cans from the auto store and go crazy.
Old Dec 14, 2017 | 05:43 AM
  #39
92gli's Avatar
Went to two good known body shops around my area. They said they would fiberglass the area put some sealant, then paint. But neither of em mentioned putting a rust converter or something similar to por-15 on it. Now I’m thinking I should be doing this myself. Haha
Fiberglass? Wtf?
I'll tell you from experience (I had a lot of it as I tried to keep my old mazda 3 rocker rust from spreading), Por15 isn't durable enough for areas like the rocker pinch welds that will get pelted with debris. I prepped everything exactly per the directions and the por 15 ended up peeling off after it got a few chips in it.
Paint the effected areas with bedliner and a foam brush. Dab it on, thick coat. It shrinks a little when it dries so do a 2nd coat and make sure you fill any pinholes. This will dry hard as a rock and you can paint body color over it. (Make sure you get the backside of those areas too.)
Old Dec 14, 2017 | 07:16 AM
  #40
hoobastnk90's Avatar
I used to drive my first S2000 in the snow all the time I live in the STL with good blizzak tires the thing was a snow beast! Not to mention all the fun that was had sliding it around! I wasn't to worried about rust, I just kept up with washes and the underbody spray and never had any problems.
