Dry Ice Myth
Originally Posted by Kenpo_S2000,Jun 15 2007, 10:21 AM
I was thinking more of the hair dryer with upside down can. I wouldn't waste money on dry ice, I believe it is pretty expensive.
Why is it that I am thinking you need to ice it first and then heat it second?
Cold contracts and heat would expand and 'pop' the dent out - right?
EDIT
I stand corrected after searching and watching this video. Still I wonder?
http://www.metacafe.com/watch/501379/remov...with_airduster/
EDIT
But, do you do this on the outside of the panel? or the inside? I would think that it would stretch our paint because we have thinner paint then most cars.
Who else has information on this?
I started using this method of dent repair back in the late 60s and it does work very well
Firstly here can be no crease in the dent at all. For this to work it needs to be a smooth dent with no defining edges or creases. If you have a high end hair dryer that will work just fine. If you have a cheap one don't even bother thrying to remove the dent. You can use a heat gun on low power, being careful not to get to close to the paint, but getting the area in and around the dent very hot. Immediatly lay the dry ice over the entire dent. You should hear some creaking and then a pop. Take the dry ice away, let the entire area cool down, wipe off any residue and look to see that the dent is entirely gone. If it did nothing than it is time for paintless dent repair.
On a lot of newer cars with thin sheet metal I can usually get good results with this method. In fact I did this to a car that suffered hail damage and looked great after. It was not perfect, but it was a hell of a lot better!
Originally Posted by OCMusicJunkie,Jun 15 2007, 10:15 AM
Paintless removal is like ~50 bucks.... I wouldn't waste too much time doing this. How much does dry ice cost anyway?
$50 is like only for dreamcation meet price... I think
Andre
Dec 3, 2001 11:51 AM
