Dyno 9.7.07
Old Sep 8, 2007 | 12:04 AM
zbrewha863's Avatar
Default Dyno 9.7.07
Hey guys, today I had my prototype RS*R 70mm single exhaust installed, it's a very nice, free-flowing exhaust (does have one resonator, but it doesn't do that much ) ... I could go into my thoughts, but I'd rather hear yours.
The first two runs (baseline) are in blue, the second two runs (w/ exhaust) are in green & red. The pulls were basically done back to back w/ no ice on engine or manifold, and on the second pull of each set of pulls the aux. fans kicked on, so the engine was muy caliente.
Take a look.
Old Sep 8, 2007 | 01:14 AM
MikeyCB's Avatar
What's with the extra 10lbs of tq on that one baseline?
That is unimpressive. But it's louder so it feels faster. And we all know that's most important
Old Sep 8, 2007 | 01:21 AM
zbrewha863's Avatar
LOL right?
No, the weird thing is that it definately IS faster -- besides the fact that it cut about 30-35lbs off my car, I can now spin the wheels on the 2-3 and 3-4 shifts, and chirp the 4-5 if I feel like it. The car is definately feeling faster, which has nothing to do w/ sound (since I've had other exhausts on as well). The dyno just sucks!
Old Sep 8, 2007 | 07:14 AM
negcamber's Avatar
Dropping 30lb is like dropping a half tank of gas...I can tell the difference.
But it goes to show how good the stock exhaust performs...it's just heavy.
Old Sep 8, 2007 | 09:05 AM
gomarlins3's Avatar
The dyno may not show huge gains, but as already stated, the weight savings is more than worth it I would think.
Old Sep 8, 2007 | 09:35 AM
zbrewha863's Avatar
Yeah, I thought someone would have pointed this out by now, but if you look at the AFR it sucks! I'm running an AFR of like 12, for some reason after we put on the exhaust the AFR got about a point richer, I think it's that we didn't give the ECU the time to learn the exhaust, not totally sure though.
Old Sep 8, 2007 | 09:41 AM
Nate4635's Avatar
those are uncorrected #'a right?
Not sure of the elevation of FL, but I'm sure that wouldnt throw it too much
Old Sep 8, 2007 | 09:53 AM
zbrewha863's Avatar
Yes these are uncorrected. FL is pretty much at sea level, so not a big deal, but it was also about 92* and 80% humiditiy the entire time, so that undoubtedly has an effect on the #s.
Old Sep 8, 2007 | 09:09 PM
zbrewha863's Avatar
Follow-up post -- when they dyno'd my car (after exhaust was installed) there were a couple issues ... first, the auxillary fans turned on, which means that the engine was hot, probably not optimal for dyno #s. Second and more questionable, the rear dyno straps were interfering with the RS*R exhaust, so they had to roll the car back a little bit on the dyno and strap it down differently -- as far as placement, normally when you dyno the rear wheels are right at the edge of the rollers; the second round of pulls was done with the wheels right on top of the rollers -- would that make a difference?
Old Sep 8, 2007 | 09:15 PM
rocrfella's Avatar
I can't see the magic numbers. What's the point of upload the results and we can't see the numbers?
