E brake/drift
Old Oct 30, 2006 | 09:41 PM
LovintheVtec's Avatar
Default E brake/drift
where could i get a new e brake cable. Preferably a more heavy duty one because my wheels dont lock when i try to use it for drifting.
Old Oct 30, 2006 | 10:55 PM
innovation's Avatar
be safe if you find one tho. dont want to see another wrecked S.
i think u can adjust it tho.
Old Oct 31, 2006 | 05:26 AM
AlX Boi's Avatar
It should lock if you yank quickly and all the way up. Not doing so will result in crappy drifts in any car.
Old Oct 31, 2006 | 05:38 AM
Synchromesh's Avatar
get a drift button!
Old Oct 31, 2006 | 05:44 AM
deathsled's Avatar
if you're using the ebrake you're not drifting, you're just yanking the ebrake.....
Old Oct 31, 2006 | 05:48 AM
MULDER's Avatar
Nah... thats mad JDMDriftActionYo!
Old Oct 31, 2006 | 05:51 AM
PoLe_PoSiTiOn's Avatar
but if you must do it then i suggest either tightening the cable you got or learn to yank the E with more sudden force. i think the e-brake is designed to not cause you to lock up if at all possible unless you really yank on it hard.
Old Oct 31, 2006 | 05:52 AM
AlX Boi's Avatar
naaaw d00d. A lot of professional drifters are using the ebrake to start their side nowadays. It's the easiest way to start the drift, and once you release the ebrake, you can continue with using other techniques like power over and such. The important aspect is maintaining a high rpm along with throttle control after the ebrake it released.
Ebrake yanking on a FF for sure is just a spin. In an FR, depending on how long and how much you turn the steering wheel, the ebrake could produce a variety of tricks.
Hence, don't hate the ebrake.
Also, I haven't seen a drift button that fits on the S2000 yet. Cusco seems to make drift buttons for a lot of cars but our car. Hmmm...
Old Oct 31, 2006 | 05:53 AM
Dark's Avatar
to bad you dont drive an ap1, a simple lift of the throttle in a turn will earn you some oversteer
mixwell
Jun 7, 2014 05:25 PM
hariku821
May 26, 2009 02:54 PM
Fantasma
Aug 20, 2007 07:50 AM
rai
Sep 19, 2003 08:26 PM
soru81
May 18, 2003 05:47 AM
