E-Brake Light Problem?
Old Oct 10, 2006 | 06:03 PM
KJ1225's Avatar
Default E-Brake Light Problem?
Hey guys, lately I noticed that my e-brake light comes on even if the ebrake is not engaged. I would be driving and it would come on... then go off... then come back on. Or i would take a left turn and it would turn on then after the turn, the light turns back off
anyone have any idea on this issue?
Thanks!
Old Oct 10, 2006 | 06:19 PM
Chazmo's Avatar
Have you checked your brake fluid? I could be wrong, but the brake light might measure fluid in the master cylinder reservoir as well as the e-Brake being pulled.
Old Oct 10, 2006 | 07:27 PM
Robs14's Avatar
Yea check the brake fluid, the same thing happened in my 240 and it ended up being low brake fluid.
Old Oct 10, 2006 | 09:32 PM
KJ1225's Avatar
ok cool guys I'll check it out tomorrow!
Old Oct 10, 2006 | 10:01 PM
jakub2000's Avatar
It has nothing to do with beak fluid. There is a switch sort of sensor right under the handbrake (just take off the center console and have a look). I had the same problem and it went away on it's own while the car wasn't driven for 45 days.
Old Oct 10, 2006 | 10:28 PM
stooken's Avatar
Yeah it's on my accord too. I got used to seeing it there. The brake fluid is full. I'm just too lazy to fix the sensor.
Old Oct 11, 2006 | 01:55 AM
minh's Avatar
brake fluid is the first thing i would check, second would be the switch
(yes, low brake fluid will cause the brake light to comes on)
Old Oct 11, 2006 | 04:52 AM
gti2000's Avatar
When this began happening to my car I had to replace the front brake pads. Once you do this the brake fluid should go back to normal.
I would say check brake pads & fluid.
StinkyTofu
Jul 21, 2025 05:04 AM
RedSunS2K
Mar 31, 2014 06:23 PM
S2k4mee
Apr 7, 2012 01:44 PM
kerm1t
Jan 24, 2012 06:40 AM
ideugene
Nov 20, 2005 11:32 PM
