Effects of Plexus on plastic windows
Originally posted by twohoos
For simple "clouding" and minor scratches, any of the above products will work. However, if the plastic has become yellowed, there's probably nothing to be done. That's UV damage. In the extreme case, the window becomes an opaque yellow and may be brittle or cracked. (You've probably seen older Miatas with this problem.) To prevent this damage, use 303 Protectant after applying your polish of choice.
Even if it is yellowed, you have nothing to lose but a few bucks trying.
Originally posted by Muz
I use a special polisher called a 'girlfriend' for the inside
Back in the beginning of the S2000 age, one phrase came to mind immediately after reading your post.
"In order to successfully clean the inside of your plastic rear window, you'll need a girlfriend with arms like an Gibbon."
hornyhonda
Feb 11, 2004 05:29 AM
