Eibach spring makes handling worse?
Old Jun 28, 2007 | 02:17 PM
RED MX5's Avatar
Originally Posted by xxlap1xx,Jun 26 2007, 09:36 PM
I bought a used 05 S2K that came with Eibach pro springs on stock shocks, for some reason everytime I go through corners ( the road is not perfect ) with around 75mph. I tend to have pretty much of oversteer and understeer, im just having a hard time follow the line and keeping my car stable. I just got four new tires, they're all Z rate, so they should have a lot of grip. Or could this be caused by my alignment? Also, my steering wheel is tilted to the right a little bit, not much, could this be the reason? Or is it because of my car dont have TCS and VSA?? Anyone have the same problem??!! HELP ME PLZ!!!???
The Eibach Pro Kit was actually designed for use on the early AP1's, and your AP2 is quite different. I have a Pro Kit on my MY00 car and the changes to the stock handling were minimal, certainly much less than the difference between the handling of a stock MY00 car and a stock MY05 car like yours. Since the springs weren't actually designed for your car you might want to consider replacing them with stock springs.
However, your tires and alignment are probably also contributing to the problems you're experiencing, and on top of that, the "problem" could simply be that you need some time to adjust to the cars quick handling. Most of us require a period of adjustment.
Do get correct tires on the car! The wrong tires can make the car unstable and unsafe.
Do get the car aligned after the new tires are installed.
Consider getting a set of OEM springs to replace that Pro Kit. It's not designed for your MY car.
Old Jun 28, 2007 | 02:33 PM
NNY S2k's Avatar
Originally Posted by Pointblank,Jun 28 2007, 01:36 AM
Problem #1, get matching tires.
Old Jun 28, 2007 | 02:36 PM
villain2000's Avatar
My car felt twitchy and unplanted especially in the rear before the alignment after the drop with the S. Techs. Get the alignment first and foremost you will notice a difference. Mine now handles at least as good as stock.
Old Jun 28, 2007 | 02:49 PM
RED MX5's Avatar
While it was not related to the lowering, we accidently go the rear toe on my car set too close to zero, and the handling at speed was downright scary. Alignment on this car is quite critical.
Same goes for tires and tire pressures.
HOWEVER, the Pro Kit spring rates are just WRONG for an AP2.
They may not totally trash the cars handling (I'm not really sure), but they are certain to reduce stability.
I think this is the sum of a number of issues, all of which need to be resolved to get the car to handle properly.
Old Jun 28, 2007 | 05:16 PM
Pointblank's Avatar
Yes, what RED said, tire pressures, make sure your local tire shop didn't put them too high. I took my RE050a's to get mounted at my local shop, the guy tried to put my tires at 40psi !!!!!
Old Jun 28, 2007 | 06:47 PM
tof's Avatar
tof
If the car is lowered it must be re-aligned. I doubt it ever was. Lowering the car changes the suspension geometry.
Also, does it transition between oversteer and understeer without you doing anything or does it switch between them depending on throttle and brake?
If your steering wheel is actually tilted an alignment won't fix it but a frame machine might. Was the car ever wrecked? Did you get a carfax on it before you bought it?
Tire advice above is also good. And some of the instability may be tramming depending on how "not perfect" the roads are in those curves. This is when the wide aspect tires tend to make the car follow road imperfections.
Old Jun 28, 2007 | 06:48 PM
tof's Avatar
tof
PS: Care looks GORGEOUS!
Old Jun 28, 2007 | 07:16 PM
xxlap1xx's Avatar
what is the right amount of PSI should my tires have?? does it have to be the same PSI for all four tires??
Old Jun 29, 2007 | 12:44 PM
iam7head's Avatar
it's in the manual, it's in search, it's everywhere if you did a search.
32psi cold all four corner.
that's a good starter number for stock car in the street, on the track you can play around with it more, FYI the rear i run 34-35psi vs 32 front
Danwolski
Sep 30, 2012 05:55 PM
xxlap1xx
19
Jun 26, 2007 11:23 PM
xxlap1xx
Jun 6, 2007 02:57 PM
n'C Honda
Aug 15, 2004 01:42 PM
