Engine Coolant Temperature and VTEC
Old Aug 12, 2001 | 07:45 AM
umvue's Avatar
Default Engine Coolant Temperature and VTEC
Recently, I occasionally have problem with VTEC. Sometimes when it goes to 6000rpm, it just bounces back and forth even if I floor the gas pedal.
Later I suspect it might be related to the engine coolant temperature. So I tried to VTEC at different number of bars at the coolant temp gauge.
It seems to me the problem happens when there is only one bar at the gauge. Does that mean the engine needs warm up to engage VTEC? Or is it just my problem?
If it is not only my problem, will my engine take a toll when I VTEC it at one bar?
Many thanks.
Yee Man
Old Aug 12, 2001 | 07:52 AM
lvs2k's Avatar
You should always let the engine warm to three bars before engaging VTEC.
Old Aug 12, 2001 | 08:33 AM
xviper's Avatar
Actually, without 3 bars, it won't let you VTEC.
Old Aug 12, 2001 | 08:37 AM
Utah S2K's Avatar
Honda has built several temperature related protection devices on the engine. Previous posters are correct, without three bars, when you hit VTEC the fuel will shut off.
Old Aug 12, 2001 | 09:13 AM
mingster's Avatar
well...if you have an aftermarket thermoswitch/stat set, the operating temperature may be ok for VTEC, but you'll only see 2 bars.
Old Aug 12, 2001 | 10:22 AM
umvue's Avatar
Thanx for your replies. Next time I will watch out for the temp.
BTW, I can't find this in FAQ, I think we should add it if it is not there.
Yee Man
Old Aug 12, 2001 | 01:34 PM
hoof's Avatar
In general, high RPMS plus cold engine equals excessive engine wear/tear, esp. if you do it before the oil has a chance to circulate through the engine. In addition, WOT on a cold engine is a bad idea for the same reason (when the engine starts, you're effectively running it as if you'd drained all the oil out). I have no idea how long it takes to circulate the oil, but I usually hold off on anything other than gentle low-rpm driving until I see 3 bars. However, once 3 bars show up, it's WOT city! =) =) =)
I have documentation at work where even a JadgTiger (WW2 German tank destroyer) was recommended against >3000rpm usage until it's warmed up. Seems that some things never change (I make WW2 combat sim games for a living, thus why I have access to that kind of info)
Old Aug 13, 2001 | 11:04 AM
MarkS2K's Avatar
just FYI, when the engine isn't warmed up, the rev limiter usually kicks in around 7500 RPMs. I did that a few times before I found out that you had to let the engine warm up before vtec'ing.
Crobin_1
Mar 22, 2014 08:21 PM
frankdatank91
Oct 7, 2012 09:12 PM
SIX SPEED
May 15, 2006 01:54 PM
jimpom23
Jul 5, 2005 10:50 AM
thrackley
Oct 20, 2002 07:29 PM
