Espeirl vs. Tein S tech springs
How you doing guys im still trying to decide wich of the two to go for haven't found much help here... i have all specs but no testimonials. are Espeirls too low? for DD S?
how is the aligment on these? can it get aligned with OEM specs?
Teins lowers front more than back 1.02/0.98 and not as stiff as Espeirl
Espeirl 1.3 all around? i hear it lowers the back more than the front?
my aplication is an 04 ap2 oem wheels oem shocks DD, no tracking
I would suggest a search but here are my thoughts. Both brands are very good. The Teins are a more mild drop but the espelier's are indeed a bit stiffer. The drops may vary depending on how the springs settle.
As far as your alignment goes, you can set that up anyway that you like, S2K's have camber adjustment. I opted for the Tanabe GF210 (nice 1" drop (perfect for crappy Chicago roads), and slightly firmer springs rates from stock) and I have the euro spec aligment. I found that the Tanabe's are a good combination of the S-Techs (drop) and the Espelier (spring rate). Car handles great.
i had the S-techs for awhile and i acutally enjoyed them no problems overall it was a 1in drop all around. now ive decided to get the espelirs springs which ive heard nothign but good things about them! i was lookin for more of a drop so the Espelirs will fit perfectly cuz i didnt want more than the 1.3in drop
I have the espelirs and there is no issue using this car as a daily driver. I even have an x-brace and exhaust, both of which slightly decrease ground clearence by themselves. You just need to know how to take driveways, speed bumps, ect... and also know when something is simply not a good idea to cross. A couple of times I've been in a driveway and actually did a U-turn to avoid a speed bump... but those moments are few and far apart.
, now hows your aligment? is there issues on that? uneven tire wear? im only intersted in best tire life posible hence would like OEM spec aligment....posible with Espeirl Springs (1.3 drop)?thanks alot again
Originally Posted by gabster,Dec 26 2006, 12:50 PM
awsome good to know, this is the kind of info i need
thanks alot again
Like I said, you need to make sure you'll willing for a little bit of a trade-off. Having a lowered car isn't nearly the huge deal I expected... you just need to realize your limits and not drive down 45 degree driveways simply because there is someone waiting behind you. 99% of the time, all you need to do is take driveways slowly at an angle, and speed bumps at a crawl. It becomes second nature very quickly. I'd do it again for sure.
JDMricist
Mar 27, 2012 11:04 PM
