Finding the limits.
I think the problem stems from a different type of oversteer than what you're describing. I think the tailhappy-ness that is getting certain folks into trouble is sudden deceleration while turning. Try going into a corner, hard, at high RPMs and right before the apex let off the gas 100%. Yep, stupid thing to do, but I think that is what is causing the problem for so many people.
One of the nice things about the S2000 is you can vary the handling characteristics with the setup. I get a lot of "snap" with the Hankook tires, but I tolerate that because it does not snap with the Kumhos. Your sway bar and shock settings can affect this also.
Hey, RedMX5, was that the PCA autocross in Macon in your video?
TRD, I do believe you missed the point of RED's post...
RED_MX5, out of curiousity, what tires were you running? OEM S02's?
In recent autocrosses (using Kumho MXs), I think I may have experienced that before, but I don't have a video cam setup, so I can't directly compare. If I am remembering the sensation and reaction correctly though, I agree with your observation. Typically (just out of habit), I'll try reducing the steering input a bit, a small bit, as well as reducing the throttle input just a little.
I've never run on S02's so I don't know their handling characteristics, so I'd wonder if the mainstream opinion of the AP1's handling is based on those tires.
Anyway, I'm nowhere near a seasoned autocrossing veteran, so take my opinion with a grain of salt
Originally Posted by ZX11,Apr 2 2008, 07:06 PM
Hmm, I took the snap oversteer as relating to when the car is using all or almost all its traction for cornering and very little is left for ham fisted throttle control. The high traction is upsetted by poor throttle control or vtec hp step. Once the traction is upset the car momentum and reduced traction from sliding (sideslip) prevent the car from returning to the intended path. That video looked like 30% of traction was used for cornering and 70% for accelerating out of the decreasing radius. Step the rear out in a steady hard corner where almost all the traction is being used for cornering and see if the throttle can save it. Or am I barking up the wrong tree?
If you take a look at the animated gif in my signature, you'll see that the same thing works when it's all slide and no acceleration; Simply modulating the throttle (and countersteering) gets the car to stop rotating.
Whether or not you can catch any given slide depends to a very large extent on how soon you catch it. You've got to recognize your mistake soon enough, and correct quickly and accuratelly enough, regardless of the cause.
The S2000 doesn't really exhibit "snap oversteer" as such, but it can snap the tail out very quickly under the right (or wrong
) conditions, and it can catch anyone off guard. In such cases, I think luck matters more than skill or practice.
I assure you, the car would have spun, almost instantly. When the back end steps out you have to do what you see in the video, and *modulate* the throttle, rather than just getting off the gas in a panic.People do that (panic and let go of the gas) quite a lot, but it's not really stupid. It's just a natural reaction when you realize that you're about to spin. Problem is, the natural reaction is the WRONG reaction.
Does that make more sense to ya?
Great event. One of the most challenging courses I can recall.
