Front drivers side tire looking worn, typical?
That looks excessive toe possibly in combination with excessive negative camber on that wheel. Take it to a better alignment place. FYI I usually only get about 5-7K out of a set of front RE 050's and 3-5K out of rears, but with much more even (though camber biased) wear.
I had the same wear on both front tires on an 06 at about 25k. I assume it's negitive camber. My car was aligned at the factory, and hasn't been touched since. The wear was enough to activate VSA. I'd get VSA in situations where it wouldn't have been needed 5k earlier.
Jason, keep an eye on the inside edge. Mine looked great on the outside, but were fairly well worn on the inside.
The tires don't last long anyways, I've replaced two sets at 14k miles each (rears were a little more worn than the fronts), but I didn't have uneven wear to the degree you do. Agree with other posters about alignment.
