Front grill questions
Old May 6, 2023 | 11:49 AM
A.O.'s Avatar
Default Front grill questions
2005 AP@ grill questions. Seems like mine had been glued in at one time and has come loose.(pretty sure it isnt supposed to be glued in) The grill itself "looks" intact, I'm trying to find out how it is supposed to be attached. The part is still available if I need to get another but as I said not sure how it is supposed to be attached. Seems like there should be some sort of mechanical fasteners, but I'm not finding anything. A "fish" type photo would be nice.
Thanks.
Old May 6, 2023 | 01:48 PM
JWN6264's Avatar
This is the 2000-2008 service manual. Check in the Body section for the front bumper info.
https://s2000.club/OM/2000-08%20Honda%20S2000%20SM.pdf
Old May 6, 2023 | 04:07 PM
A.O.'s Avatar
Oh yeah I forgot I had that, thanks. Looks like I have to remove the whole bumper to get at it! Sounds like a project, but I think I’ll order the grill while they still have them.
Old May 7, 2023 | 10:25 AM
THNY's Avatar
The grill on my S did the same thing. There are small clips that hold the grill into the backside of the bumper that seem to fail very easily. The glue on yours was probably a fix done by the previous owner. I fixed mine by taking the bumper off and drilling holes for small thru-bolts where the grill and bumper tabs overlap. I did 2 along the bottom and 1 on each side face and used black anodized hardware so its barely noticeable. You could also try to fix it with glue again.
Old May 7, 2023 | 10:35 AM
A.O.'s Avatar
Yeah, I did some spot gluing for now to keep it in place, but your solution sounds like a good one. How hard is it to R&R that bumper?
Old May 7, 2023 | 12:42 PM
Car Analogy's Avatar
I'm thinking of doing tbrough holes then se of those plastic rivots that are so ubiquitous holding plastic together in modern cars.
Will try to find something with low profile head and small through hole.
Old May 7, 2023 | 02:08 PM
noodels's Avatar
^Thats the method i have,like the trim 2 piece clips thats in the trunk ect
Old May 7, 2023 | 03:12 PM
A.O.'s Avatar
I wonder if those could be drilled from the outside without removing the bumper?
Old May 7, 2023 | 04:47 PM
Use something like this, along with 1/4" hex drive drill bit:
90 degree driver
Old May 8, 2023 | 03:55 AM
A.O.'s Avatar
90 degree driver
Looks nice, but I'm thinking I probably have a 90 degree adapter out in one of my tool boxes. The hex drive on this sure makes it a lot narrower though. And mate that with a set of stubby bits and I think we're in business.
NEIKO 11402A Stubby Drill Bit Set for Metal | 5 Piece | 1/4" Quick Change Hex Shank | M2 High Speed Steel | for Quick Change Chucks and Drives | Drill Bit Holder Included - - Amazon.com NEIKO 11402A Stubby Drill Bit Set for Metal | 5 Piece | 1/4" Quick Change Hex Shank | M2 High Speed Steel | for Quick Change Chucks and Drives | Drill Bit Holder Included - - Amazon.com
