fuel stabilizer
As important as fuel stabilizer is (Sta-Bil and Sea Foam) be sure to top off the fuel tank to prevent condensation and water vapor absorption. You can get a jerry can and top it off when the car is in place. Try to use fuel with as little ethanol as possible. Use a battery minder if you can.
I top off the gas tank and hook up the battery tender.
Top up but UNLATCHED, tranny in reverse ( these from owners manual). Parking brake OFF.
Skipped Sta-Bil last fall, no ill effects.
Owners manual says start up and run ( each month?). I don't do that.
Dryer sheet over the air intake ( mice built a condo in there 2 years ago)
Dryer sheets and mint/cotton balls on floor in side.
markhs2
Oct 30, 2017 02:53 PM
s2kdriver80
Oct 6, 2003 03:09 PM
. I would like to know if there is a specific fuel stabilizer I should use?
