Fuse puller
Old Feb 21, 2011 | 04:35 PM
gbaker's Avatar
There is one. Mine is in a spare slot in the fuse block in the engine compartment - 2001 s2k.
Mine is a tiny thing whitish/yellow about 1" square open ended with the ends hooked to grab the fuse and pull - push in with fingers.
I have found out that a pair of needle nose pliers work best if you are dealing with the standard plastic push-in stabbed contact fuses.
Round glass fuses(which I am not sure the S2k has) are best yanked with a special made fuse puller(pliers could crack the glass tube). Small pullers are found at Auto/Electrical supplies or maybe Lowes/Home Depot electrical dept.
My old 240Z's had a terrific glass fuse puller about 3" long. I miss those.
Old Feb 21, 2011 | 05:03 PM
JackS's Avatar
Thanks to everyone for their answer. I did wind up using a pair of needlenose pliers and suspect that the puller is somewhere behind the panel.
Old Feb 21, 2011 | 05:13 PM
radcliffe1's Avatar
Even if you find it you'd have to be pretty limber to even contort into postion to pull a fuse.
I need to switch a fuse and am waiting until the 14 month is old enough to understand so he can get in there and do it for me -LOL.
Old Feb 21, 2011 | 07:45 PM
fastD's Avatar
I also had a 72 240Z with an awsome fuse puller....
Old Feb 22, 2011 | 04:30 AM
BumbleBee01's Avatar
just like everyone else mine was there too.
Old Feb 23, 2011 | 09:53 AM
obsess2k'ed's Avatar
umair
Nov 5, 2015 05:01 PM
kimimila
Jul 14, 2011 10:32 AM
yuning83
Mar 22, 2011 10:04 AM
TypeS2000
Mar 30, 2002 05:42 AM
