Fuses/Radar Detector Install
Old Jan 2, 2001 | 12:08 PM
Randy's Avatar
After reading the post referencing the available fuse circuits, and seeing them listed in the FAQ on sk2i.com, I checked them out...
On my 2001, the last three fuse sockets I assume everyone's referring too, (25-27 in users manual) are devoid of any contacts!
That's right, no metal, no connectors, no nothing.
The daytime running lights circuit (#14) is hot w/o key, so could be good for security system since there's assumedly nothing else on it.
My only thought for the radar detector however, would be the Accessory Socket (#5) as it's switched and wouldn't have another load.
Is this different than 2000 year s2000's?
Does anyone have any better switched lines or recommendations on running the wiring up for a detector?
Thank's beforehand!
Randy
(proud new owner of Yellow '01)
(proud old owner of an '88 Fiero GT)
Old Jan 2, 2001 | 12:28 PM
cdelena's Avatar
These are called optional connectors and if you look under the dash on the drivers side they are on the left side of the fuse box. Every one I have looked at has blades in them.
Old Jan 2, 2001 | 12:50 PM
Prolene's Avatar
The slots easiest to see for me didn't seem to have any connectors in them. I used the fuse for the audio (sorry don't remember number), since when the car is off, I don't mind the detector off, and since the fuse adapter said 10 amp max for any attached fuse, and the audio uses 10 amp.
For hot line I used a bolt that holds the hood latch handle at left of driver's knee (lhd car).
Old Jan 2, 2001 | 12:53 PM
Randy's Avatar
Thank you CDelena!
(But brr.. This detached garage concept is chilly!)
That was the extra info I needed, I was looking too closely at the fuses (which are on the right) and didn't have enough info from the earlier posts to look on the left.
So the next question is, are those circuits fused or not? (IE, do I need to include an inline fuse when wiring to them?)
Randy
Old Jan 2, 2001 | 03:41 PM
cdelena's Avatar
[QUOTE]Originally posted by Randy:
[B] So the next question is, are those circuits fused or not?
Old Jan 3, 2001 | 05:14 AM
Pinky's Avatar
[B] Thank you CDelena!
(But brr..
Old Jan 3, 2001 | 05:59 AM
Prolene's Avatar
klein1223@mac.com
Oct 27, 2008 02:37 PM
yyyiiikes
Sep 8, 2005 08:26 PM
bguernsey
Jan 2, 2003 03:34 PM
S2KXLR8N
Nov 4, 2001 10:12 PM
Tfunk
Apr 16, 2001 11:19 AM
