Gas cap sticking?
Old Jul 6, 2005 | 12:59 PM
tcho82's Avatar
Default Gas cap sticking?
I know there is a TSB specifically for this, but I am wondering, do your gas caps spin on very loosely then tighten? Or do you kind of have to churn it on a bit for it to close. I brought it into the dealer stating this problem, and the tsb in hand, they told me the threads looked fine to them, but it seems that this keeps happening to me so I dunno if I should take it in again. The Check engine light keeps coming on because the gas cap gets loose, but wanted to know if your gas caps were really loose(as in does it spin on, or do you have to kind of crank at it to shut it) or are also kind of stiff to close.
Old Jul 6, 2005 | 02:08 PM
ol' dood's Avatar
Geez guy, this is an easy solution. Just spin the cap on normally, and then, grasp the outer edges of the cap with BOTH handsSpread your fingers around the edges of the cap and squeeze and squeeze while you tighten it. Tighten the cap in this fashion until it clicks a couple a times. This will TIGHTEN that cap thoroughly and you'll NEVER get that code again!
Old Jul 6, 2005 | 02:12 PM
s2000flog's Avatar
Old Jul 6, 2005 | 02:13 PM
mike-mz's Avatar
So weird, I just bought an '02 a few weeks back. My check engine light came on this morning - major pucker factor - found my gas cap was loose - lots - I got about a turn before it clicked. I figured it was my fault - maybe not. I'll certainly be paying attention to cap tightening.
Thanks
Mike
Old Jul 6, 2005 | 02:33 PM
tcho82's Avatar
Uhm ok, that didnt really answer my question. Obviously I'm asking do you or do you not have this problem with your gas cap. If I'm the only one who has this problem then I will try to get this fixed under warranty like the TSB states, but I thought I would just ask to see if other people had an issue like this first. I don't plan on using a workaround when I can get something like this fixed under warranty
Do your gas caps spin on, or are they sticky, I ask this question because I have an 00 Accord and my gas cap spins on, and then its just a few clicks and its done. My s2k does not, and take manual churning to get the gas cap on. I have been making sure the gas cap is clicking as well after I am done, but the gas cap still has been coming loose every now and then.
Old Jul 6, 2005 | 03:00 PM
slalom44's Avatar
Top Answer: 1
I had this same problem. At first, I thought the gas cap was coming loose. I now believe that the threads on the filler tube did not have the correct form, causing the gas cap threads to deform. In time, the deformation on the gas cap threads gets worse, causing them to bind before the cap is on tight. You can tighten the cap as ol' dood suggests, but it only gets worse.
The cap isn't coming loose. It wasn't tight in the first place because it was binding. The threads on the cap relax over time, causing it to not bind anymore.
Last year, I took my car into the dealer with this problem. I didn't know of the TSB at the time. They replaced the cap and the problem seemed to go away. A year later, it was back. I lived with it for about 6 months, and it got worse. It became so bad that I could barely get the cap off, twisting with both hands. I took it back to the dealer, mentioned the TSB and showed them the problem. The mechanic couldn't believe how bad it was.
They replaced the filler tube and now it works like it should.
Old Jul 6, 2005 | 04:03 PM
ronblanford's Avatar
Mine is sticky. It wasn't that way when the car was new, but developed in the first year. I use the ol'dood squeeze method and have never had a CEL.
CoolGuy094
Jan 10, 2015 06:36 PM
paul__chen
Mar 30, 2009 08:56 AM
TJF
May 28, 2008 04:06 PM
PuFF
May 15, 2008 01:00 PM
dmw16
Sep 12, 2006 10:35 AM
